CrapBay keyfob
Discussion in '2nd Gen Tundras (2007-2013)' started by Kevin2009tundra, Nov 17, 2023.
  1. Nov 17, 2023 at 11:01 AM
    Kevin2009tundra
    Kevin2009tundra [OP] New Member
    Kevin
    2009 Tundra 5.7
    Hello all, new to the forum and Im sure this has been discussed plenty of times but I looked through 3 pages and didn’t see any. Any help with programming a new keyfob? I have tried the two from googling, the open door twice thing and the lock/unlock 5 time thing. Neither of these will work and tried for a good half hour to get them to so pretty sure at least once I got it right and nothing. Any help would be greatly appreciated. Just purchased a 2009 tundra ext cab. Thanks again!
  2. Nov 17, 2023 at 11:05 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I had to go to the dealer to get an aftermarket keyfob programmed. I also tried the door program thing. It didn't work for me either.
  3. Nov 17, 2023 at 11:17 AM
    Kevin2009tundra
    Kevin
    2009 Tundra 5.7
    Well crap, was hoping to avoid that but will probably have to pay that man his money!
  4. Nov 17, 2023 at 12:34 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Call a local locksmith - they often have the software to do it and in many are way cheaper than the dealership. Nissan wanted to charge me $400 for doing it when I had my Titan.....I called a local locksmith after buying a FOB online and he charged me $75.
    apwisher likes this.
  5. Nov 17, 2023 at 1:16 PM
    Kevin2009tundra
    Kevin
    2009 Tundra 5.7
    Good to know, thanks.
  6. Nov 17, 2023 at 4:26 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    Buy Techstream from Amazon and install the software on a PC. Use that to program the key and remote.
    If you're programming the key and not just the fob, verify that the chip matches your key, because there are multiple chips (such as G and "dot") that are incompatible with each other.
    Thumper_6119 likes this.
  7. Nov 17, 2023 at 6:35 PM
    Kevin2009tundra
    Kevin
    2009 Tundra 5.7
    I will give this a try, thank you
    PhotoNerd likes this.
  8. Nov 18, 2023 at 9:55 AM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I have one these, and it works great. For anyone considering purchasing one, be advised, the Techstream software is jailbroke. I had to contact the merchant to get it to function on my laptop. (YMMV). But it works well, and I've programmed 2 fobs with it as well as pulled codes on my Tundra.
  9. Nov 18, 2023 at 9:59 AM
    Kevin2009tundra
    Kevin
    2009 Tundra 5.7
    The reviews made me a little hesitant to buy it because I’m a little computer illiterate. Going to check with my mechanic friend to see if he can do it before I try and tackle the Techstream deal.
  10. Nov 18, 2023 at 10:15 AM
    Thumper_6119
    Most locksmith shops will have a (licensed) Techstream setup and can whip out fobs and keys easily, and the parts and labor are considerably cheaper than a dealership. If your mechanic friend has access to a Techstream setup, they should be able to get you taken care of.
    The first time navigating through Techstream is not intuitive, especially if you're not familiar with the terminology and vehicle processes. I do IT for a living, and I still had to YouTube it.
