  1. Nov 17, 2023 at 12:07 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Installed the JL oil catch can, pretty straight forward! Heard good things about this.
    Also, parts for Secondary AIP coming in. Hoses, barbs, filter - just waiting for 1 more part from @831Tun
  2. Nov 17, 2023 at 2:20 PM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Are the secondary AIP a problem for the 2.5 gen? Or just being proactive on it?
  3. Nov 17, 2023 at 3:30 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    I’ve been eyeing an oil catch can. Had one on my last truck and it caught all the nasty stuff.
  4. Nov 17, 2023 at 3:46 PM
    DirtyMike5
    DirtyMike5 New Member
    Baton Rouge
    Oops, quick preview of the new wheels n tires
    17x8.5 alphas w 35x11.5
  5. Nov 17, 2023 at 5:41 PM
    bfunke
    bfunke Tundra Curmudgeon
    @pvn.beluga - the catch can looks kinda close to the + battery terminal in your photo. Perhaps an illusion.
    pvn.beluga likes this.
  6. Nov 17, 2023 at 6:10 PM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    To answer your question - yes it was plug and play. Easy peesy. That is such a strange response from them because when I had first purchased it (literally as soon as it came out), it was advertised (I swear it was in at least one of their videos and/or ads; maybe an influencer) that it was plug and play for all 7 pin harnesses. I have a 4 pin harness on my FJ and after adding a 4 pin to 7 pin adapter, it was plug and play as well for the FJ.
    BC Tundra[QUOTED] and bulldog93 like this.
  7. Nov 17, 2023 at 6:53 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Hah, yeah, we have about a good 2 inches from the battery terminal!
    bulldog93 likes this.
  8. Nov 17, 2023 at 6:53 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Cheap insurance if anything. If you used it before, I’d say get one again!
    CaptRussia253[QUOTED] likes this.
  9. Nov 18, 2023 at 5:24 AM
    singletrack_dad
    singletrack_dad New Member
    Ty
    2014 TRD OR CM
    Those look excellent. I also just scored those on tire rack clearance in bronze and I love them. Such a clean wheel & truck dude
    DirtyMike5[QUOTED] likes this.
  10. Nov 18, 2023 at 7:53 AM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    How difficult? Heat gun and fingernails?
    Tripleconpanna likes this.
  11. Nov 18, 2023 at 8:02 AM
    SPOirish28
    SPOirish28 New Member
    Ontario, Canada
    2014 SSM SR5 DC
    Satin black roof, 18” KO2’s, satin black powder coated steel rims, tri fold tonneau cover. Led lights interior, exterior. Trd pro grill. 13” ryonnair antenna. OEM LED headlights.
    Definitely curious about removing that vinyl pc between windows as well.. my ssm is debadged as well. Would look good I think..
  12. Nov 18, 2023 at 8:08 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    in a warm climate, just get it positioned in the sun, open the door, look for the black edge, pick at it with your fingernail and then start slowly peeling away. If it’s cool/cold out, then use a heat gun to soften it as you peel.
    I don’t think it took 30 minutes per side.
  13. Nov 18, 2023 at 8:10 AM
    SPOirish28
    Ontario, Canada
    2014 SSM SR5 DC
    Thanks! Will definitely remove them in the near future.
  14. Nov 18, 2023 at 8:20 AM
    DirtyMike5
    Baton Rouge
    Thanks buddy, you're the reason I went w +35 and not +15. I think its a cleaner look even though 20mm isn't much of a difference. I was debating bronze but my wife said it looks ghetto....
  15. Nov 18, 2023 at 8:25 AM
    Buster1
    Buster1 New Member
    Oregon
    2019 Cavalry Blue Limited TRD Off Road Double Cab
    New tires yesterday. I had BFG KO2's and love the look of them but they've had to have changed their rubber compound over the past few years. I rotated them religiously every 5k miles and they were flat worn out and wearing funny at 40k miles.
    Went with the Les Schwab Open Range AT Plus 275/70/R18's. Apparently a brand new version and not much info out there yet.
    Nbab23, Wallygator, Tundra-XP and 5 others like this.
  16. Nov 18, 2023 at 9:15 AM
    JohnWhicker
    JohnWhicker New Member
    Since my old but new 2021 is 2 weeks old I managed to add few things to it, and my 2013 is hating that I have all my attention on the 2021 :)
    - Autobahn Ceramic i3 tint - 50% Windshield and 15% all around
    - Bakflip MX4 Tonneau Cover
    - CarQI Wireless Charger Center Console Organizer Tray
    - CPLAY2air - Wireless iPhone CarPlay
    - And the list is growing day by day.
  17. Nov 18, 2023 at 12:45 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Added a little touch of wilderness to it.
  18. Nov 18, 2023 at 12:55 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    IMG_5470.jpg IMG_5468.jpg Did a bmc and flattened the seam. Also took the heat gun to it too. I also drilled new holes at the bottom to hold the liner away from tire. I already made room on the front bumper a few months ago. I’m getting 35X12.50R18 Nitto Ridge Grapplers on Wednesday. If I don’t have any rubbing, which I don’t think I will. I’ll make the plates up to get welded.
  19. Nov 18, 2023 at 2:21 PM
    singletrack_dad
    Ty
    2014 TRD OR CM
    Mounted up some wheel every weekend security mounts to my IO 87 lb rooftop tent. I’ve been a ground tent camper for years & I’ve always been a “simple camper” but I’m just tired of sleeping on the ground & my buddy hooked me up with this. I’m excited for easier & quicker camp setup.
  20. Nov 18, 2023 at 3:04 PM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    Sanded, cleaned the metal with acetone, and sprayed a couple coats of primer. Hoping to spray the finish coats tomorrow before the temps start dropping hard. I’m already on the low end for temps as it is, hope everything cures fine.
  21. Nov 18, 2023 at 3:16 PM
    That thing looks beefy. We have a full set of CBI skids on the 4Runner. Those damn things are solid and heavy.
  22. Nov 18, 2023 at 3:57 PM
    roughfisher
    JP
    Northern Minnesota
    No doubt! this thing is stout, they weren’t fooling around when they designed this
  23. Nov 18, 2023 at 4:07 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    May as well get it ready for 37s, lol.
  24. Nov 18, 2023 at 5:01 PM
    2014 Black tundra
    2014 tundra sr5
    My wife said no to 37”. :( So 35” it is. With all the cutting/grinding I did, I’m sure 37’s would fit with no rubbing. When the 35” wear out, then I’ll get 37” and get the gears changed too. :thumbsup: Tonight I sprayed some Rust-oleum on the bare metal on the bmc.
  25. Nov 18, 2023 at 5:09 PM
    biebs96
    PA
    [QUOTE="DowntownApexTundra, post: 3315569
    [/QUOTE]
    It looks like your brake line hose is rubbing on the leaf. You may need to bend the bracket, or add a piece of flat stock and extend it upward an inch or two.
    Most definitely a hose you do not want to rub through.
  26. Nov 18, 2023 at 5:10 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    good thing that is a mechanical parking brake cable.
  27. Nov 18, 2023 at 5:12 PM
    biebs96
    PA
    yea I know what I meant to say o_O
    still looks like it’s rubbing on the leaf regardless.
    BiggHertz[QUOTED] likes this.
  28. Nov 18, 2023 at 5:19 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    just busting chops ;)
  29. Nov 18, 2023 at 7:47 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    odd that it has a white rear bumper and chrome front bumper. Or did you do that?
  30. Nov 18, 2023 at 9:45 PM
    Val4x42
    Val4x42 New Member
    Phoenix, AZ
    2018 Tundra
    I was doing the same for who knows how many days.... It was messy for a while. All cleaned up well though with a shop vac later
    Nbab23, Wallygator, Tundra-XP and 7 others like this.
