Bilstein 5100 Sequoia ride height vs Tundra
Discussion in 'Suspension' started by blenton, Nov 17, 2023.
  1. Nov 17, 2023 at 9:50 AM
    blenton
    blenton [OP] New Member
    I’m curious to know if anybody has installed Bilstein 5100’s on their 2nd Gen Sequoia and what amount of lift they ended up with. I was under the impression that 5100 fronts had a setting for stock ride height but it appears that it is a minimum of .87” of lift on the sequoia vs 0” lift on the Tundra. I guess this kinda makes sense with the shorter wheel base and factory leveled stance vs the rake and longer wheelbase of the tundra.
    I have Eiback Pro truck struts on my sequoia right now which use basically the same setup as the Bilsteins for height adjustment. It might ride a hair taller in front right now than it did with the factory work out struts, but not appreciably so. I ended up with 5100’s in the rear and am wanting to match them up front.
  2. Nov 17, 2023 at 9:57 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    Yeah, the Sequoia came lower than the Tundra from the factory. Even the new 2023 models are the same, about 1-2" lower on those than a new Tundra though
    So the .87" will bring it up to the stock height of the same year Tundra, in theory.
  3. Nov 17, 2023 at 10:10 AM
    blenton
    Thanks. If only I could find a 3/4" spacer for the rear coils...
