3rd Gen Tundra Front Bumper Quality Issue
Discussion in '3rd Gen Tundras (2022+)' started by TundraFleet, Nov 15, 2023.
  1. Nov 15, 2023 at 7:29 AM
    TundraFleet
    TundraFleet [OP] New Member
    Is anyone else out there operating the 3rd Gen Tundra's as a work truck in the field (off road / gravel / dirt roads)? We are experiencing issues with the front bumper and are looking at our options, front spoiler delete module, aftermarketbumper etc..
  2. Nov 15, 2023 at 1:03 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Looks like it is falling apart? Did you hit something? The airdam can be removed and deleted CBI has a airdam delete module that should eliminate any code and warning light if you took the whole thing out of there.
  3. Nov 16, 2023 at 12:36 PM
    TundraFleet
    No, no impact has been detected (according to telematics data). We think that when the airdam is deployed, if the driver goes over a bump and the air dam is impacted, then it can cause the issue.
    Been in touch with CBI already and exploring many options
  4. Nov 16, 2023 at 1:31 PM
    xc_tc
    xc_tc New Member
    The air dam is attached to the bumper beam and not the bumper cover. How do you think the air dam is causing the damage to the bumper cover from hitting a bump? The air dam is supposed to give way when it contacts something from what I’ve heard. The mechanism is clutched so it can be pushed out of the way when it hits an object.
