Do I Need a rear alignment after installing an AAL?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Waffletractor, Nov 15, 2023.
  1. Nov 15, 2023 at 4:35 PM
    Waffletractor
    Waffletractor [OP] New Member
    Anthony
    Massachusetts
    2018 White SR5
    Do I need an alignment after installing an AAL in the rear? Installed 6112’s + 5160’s today but could not get to installing the 1.5” ICON AAL sadly (just didn’t have the time. Planning on installing Monday). I already have an appointment to have an alignment done tomorrow, and I’m unable to reschedule. Will I be okay installing the rear lift and not getting it aligned again, at least for a few weeks? I’ve heard I’ll be okay, but I appreciate the input. Thanks guys
  2. Nov 15, 2023 at 5:14 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    They’ll usually only adjust cambers caster and toe on the front. I think you’ll be fine.
    Waffletractor[OP] likes this.
  3. Nov 15, 2023 at 7:10 PM
    AndrewMT34
    AndrewMT34 New Member
    Andrew
    ID
    2017 TRD Pro
    Stage 8 Icon Decked Durobumps U-bolt Flip Kit
    The rear is a solid non-steering axle so there shouldn’t be anything to align. I think you’ll be ok to do that add a leafs after the alignment.
  4. Nov 15, 2023 at 7:14 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It reduces your front caster a little, id do alignment after
    AndrewMT34 likes this.
