  1. Nov 15, 2023 at 12:19 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    You don't drink coffee... So why would you, and why would you need to waste precious time and RAM learning the process??
  2. Nov 15, 2023 at 12:20 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I had French press coffee for the first time at buddy's in my 30s.
    It was really good so I bought all the stuff.
    I did it for a while but I'm not a morning person so I've been using the Keurig for a long time. No way I'm using the French press in the morning while getting ready for work.
    I can see it being a Sunday morning thing down the road at the new house.
  3. Nov 15, 2023 at 12:26 PM
    Ouch.
    T-Rex266 and Blue Thunder like this.
  4. Nov 15, 2023 at 12:27 PM
    Worked with a guy that had his little French press at the office. He'd just make it at his desk. Only works if you've got an office job and hot water to use, but it's an option.
  5. Nov 15, 2023 at 12:27 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Blooming the grinds is just basically wetting them to release all the gas stored inside the bean. Once the gas is released and the grinds stop foaming, you add the additional water. At least that's how I do it.
  6. Nov 15, 2023 at 12:29 PM
    Tripleconpanna
    :sorry:
    I would find a link to the process and send it to you; but I hate to :spam: the thread w/a bunch of random internet links like some seem to enjoy doing :devil:
  7. Nov 15, 2023 at 12:32 PM
    Tripleconpanna
    @GODZILLA
    Step 6: Bloom
    Start the timer on your scale and pour hot water onto your ground coffee in a slow, spiral motion. Your water should be around 200°F, not boiling; this will allow the most extraction without scorching your ground coffee. You want to pour enough water that you cover the ground coffee in about an inch of water. Make sure that all of your ground coffee is evenly saturated, and allow your coffee to bloom for 30 seconds.
    A Note On Blooming
    Blooming coffee is an important step in manual brewing, whether you're brewing with a Hario V60, a Chemex, or a French press. While your coffee blooms, you'll notice bubbles coming up and popping across the surface of your ground coffee. This is the carbon dioxide and other gasses that are trapped during roasting being released from the coffee. By allowing your coffee to bloom prior to starting the full brew you make sure that all of the trapped gasses are released instead of ending up in your cup and causing off-flavors, and it also allows the rest of your water to more fully and evenly extract all of the delicious elements from the coffee grounds.
    Entire process...
    https://nmpinoncoffee.com/brew-guides/french-press#
    T-Rex266, TILLY and GODZILLA like this.
  8. Nov 15, 2023 at 12:34 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    We used a Keurig for years. Recently bought a cheap regular coffee pot so we could have it turn on automatically and be ready in the morning. I set it for 4:50 and alarm goes off at 5. Then I started waking up at 4:30. Wife works from home and doesn't get up until 7.
    I'm back to just using the Keurig and then she can do the same or turn the pot on when she gets up. Which would be stupid because she just has one cup.
    I might look into one of the Keurigs with its own water supply line and install an inline filter. Maybe one that you can program to turn on at a certain time. I don't like leaving it on 24/7 just so the water is always hot and ready. Not sure if they make one with that feature.
    Leo's first, T-Rex266 and GODZILLA like this.
  9. Nov 15, 2023 at 12:55 PM
    Blue Thunder
    Washington
    We just have a pour over system. Water boiler and a bur grinder. Fresh ground coffee with minimal mess.
    Some french presses are decent, but they seem to have a more gritty texture cuz the mesh doesn’t catch the small grounds. I have had a good coffee from a french press, but generally not a fan.
    GODZILLA and T-Rex266[QUOTED] like this.
  10. Nov 15, 2023 at 1:55 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Most Keurigs are programable now they even have smart ones
  11. Nov 15, 2023 at 2:04 PM
    Tripleconpanna
    :annoyed:
    @Keurig now my coffee machine is following and tracking me??? :frusty:
    #alexastartmyKeurig
    #siribrewmesomefreakincoffee
    #elonstartmyKeurigbrewmesomefreakincoffeeandhaveitinmyTeslacupholder
    :nuclear:
  12. Nov 15, 2023 at 3:14 PM
    NWPirate
    Zach
    WA
  13. Nov 15, 2023 at 3:19 PM
  14. Nov 15, 2023 at 3:24 PM
    :drool::hungry:
    Details? What all are we looking at?
  15. Nov 15, 2023 at 3:27 PM
    Blue Thunder
    Washington
    Probably a vegan grass burger with organic coconut mayo. No more than 250 calories.
  16. Nov 15, 2023 at 3:29 PM
    Pretty sure Hawaii doesn't do the hippie food. Pig roasts and spam are staples, aren't they?
  17. Nov 15, 2023 at 3:31 PM
    :drool:
    Where’s the fork?
    ^^^^ + he has CrossFit later
  18. Nov 15, 2023 at 3:34 PM
    NWPirate
    Zach
    WA
    So damn good!
    Pretty much a cowboy burger with a grilled pineapple, Hawaiian style.
  19. Nov 15, 2023 at 3:35 PM
    Excellent. Now, also get some pizza with pineapple on it
  20. Nov 15, 2023 at 3:59 PM
    Tripleconpanna
    There we go!!!!!!
    :nuclear:
    I'm gonna need the ingredient list on that meal :hungry:
  21. Nov 15, 2023 at 4:00 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Damn that looks good
  22. Nov 15, 2023 at 4:00 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
  23. Nov 15, 2023 at 4:27 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
  24. Nov 15, 2023 at 5:04 PM
  25. Nov 15, 2023 at 6:15 PM
  26. Nov 15, 2023 at 6:36 PM
    NWPirate
    Zach
    WA
  27. Nov 15, 2023 at 6:54 PM
    I'm really hoping you show it to your parents. :devil:
    NWPirate[QUOTED] and T-Rex266 like this.
  28. Nov 15, 2023 at 6:56 PM
    NWPirate
    Zach
    WA
    :laugh:
    At their best my mom was 5'7 and my dad was 6'0.
    T-Rex266 and GODZILLA[QUOTED] like this.
  29. Nov 15, 2023 at 7:09 PM
    NWPirate
    Zach
    WA
    Several back surgeries later, my dad is now probably 5'10. Mom might still be close to 5'7
    Blue Thunder, GODZILLA and T-Rex266 like this.
  30. Nov 15, 2023 at 7:19 PM
    Both above average for height. Explains your Wookie height.
