Truck Bed Camping Power Setup?
Discussion in '1st Gen Tundras (2000-2006)' started by danmurphymn, Nov 13, 2021.
  1. Nov 13, 2021 at 6:25 PM
    danmurphymn
    danmurphymn [OP] New Member
    Minneapolis, MN
    Black 2004 DC TRD
    My wife, son & I are planning a few larger road trips next year.
    I feel like I have a decent camping & storage setup, but was hoping to see others who have setup electrical for their truck beds.
    I'm thinking a 10ga wire from the battery to a fuse block behind the tail light. Then a connector going to the topper. I Don't plan much. A few LED lights in the topper, a 12v charger & probably some aux LED backup lights.
    What have you seen done for something like this?
    Any pictures, links or threads you can point me to?
  2. Nov 13, 2021 at 8:27 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    I added a couple of USB and 12V plug with a 120 plug to connect a generator when I'm at the track. In your case I would determine how many lights will you be running and for how long because you might need to add a second battery to do multiple lights and not worry about draining your cars battery for start up.
    I'm also going to add some LED lights in my topper that I can run with 12v and 120v.
    dirtnsmores and HBTundra like this.
  3. Nov 13, 2021 at 8:49 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I'm following this anxious to see what people come up with.
    I've been eyeing a couple 'O-Light' brand lamps . . . one is called an 'O-Bulb' and the other is their 'Mini-Lantern' . . . small compact lighting options with decent run times on the included rechargeable batteries. I too take a small honda generator often out of necessity . . . but it would be cool to have a couple small portable lights instead of flashlights for when the generator is off.
  4. Nov 15, 2021 at 6:07 AM
    danmurphymn
    Minneapolis, MN
    Black 2004 DC TRD
    I watched this Chris Fix video last night. https://www.youtube.com/watch?v=77t1UW4Qc7g&list=WL&index=31
    While not exactly what I'm looking to do, it is similar. My only difference is that I thought about running a small fuse block behind the tail light. That way I could fuse the different circuits in the truck bed.
    LED Lights & 12v plug.
    Aux backup lights
    But that may be a bit overkill...
    HBTundra likes this.
  5. Nov 13, 2023 at 8:55 PM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Seeing if maybe I can bring this thread back to life. I had a 2nd gen Tacoma before this truck and loved the power outlet in the bed. I will be getting a camper installed in a few months and need to get power to the bed to help power something like a large Jackery power station. Don't want to necessarily install a bunch outlets... Just one is fine or even some sort of power cable. I want this to only give power if the truck is running.
    Any idea?
  6. Nov 13, 2023 at 9:17 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  7. Nov 13, 2023 at 9:18 PM
    dirtnsmores
    Southern CA
  8. Nov 13, 2023 at 10:56 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Nope, my '19 had nothing.
    I went straight to the battery 'cuz I wanted constant hot without needing to have the truck ACC or running lights on.
    cran2 likes this.
  9. Nov 14, 2023 at 6:01 AM
    dirtnsmores
    Southern CA
    I like that setup. You added a second mounting rail? My first gen has none. I may go this route.
  10. Nov 14, 2023 at 7:00 AM
    SD Surfer
    Bruce
    So Cal
    Those are actually the factory rails; my Bakflip tonneau comes with brackets that drops them down a few inches.
