Thread sealant on transmission drain plug?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundradude2018, Nov 12, 2023.
  1. Nov 12, 2023 at 10:43 AM
    Tundradude2018
    Tundradude2018 [OP] New Member
    R
    2018 Tundra SR5 5.7L 3UR-FBE engine
    Hi, this is my first post - thanks in advance for your thoughts!
    We just bought this used Tundra ~2 months ago: 2018 Tundra SR5 5.7L 4WD 3UR-FBE engine
    I drained & filled the transmission fluid for the first time. It is leaking a bit from the transmission drain plug even though I tightened it past the torque specs. I replaced the crush washer after draining it and had the flat side facing the pan. I used genuine Toyota ATF WS fluid.
    I'm leary of trying to tighten the drain plug further. I bought a new drain plug and crush washer for the next time I drain/fill.
    My question to you is this: Should I use some type of non-permanent thread sealant on the drain plug threads -OR- some type of non-permanent liquid gasket? If so, do you have a recommendation?
    Thanks!
  2. Nov 12, 2023 at 12:16 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    No. Crush washer and that it.
    nobodyintexas likes this.
  3. Nov 12, 2023 at 6:48 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I’ve never used thread sealer on the drain plug at the dealership. As already mentioned, just use a new Toyota gasket. I suspect there is some dirt between the gasket, pan or bolt. Don’t keep cranking on the plug or you will be changing the oil pan and it won’t be a good day. Remove the plug and drain into a clean container then check what the issue is.
    BTW, how did you set your transmission fluid level?
  4. Nov 12, 2023 at 7:23 PM
    bonefish
    bonefish New Member
    Peter
    Treasure Coast Florida
    Doesn't the flat side washer face the plug? Crimp side toward the pan?
  5. Nov 12, 2023 at 7:29 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I've always done it the other way around but it should still seal.
  6. Nov 13, 2023 at 3:01 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Flat side goes toward the plug. If it’s backward, that’s why you have a leak.
  7. Nov 13, 2023 at 6:04 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Considering that the gasket fits loose on the drain plug it won't make any difference which way you place it. If your thinking that the crimp side will somehow leak, it will do that regardless if it's against the pan or plug.
  8. Nov 13, 2023 at 6:52 AM
    boweavil
    boweavil New Member
    Delaware- Lower
    2016 SR5
    Hi from another new guy.
    Suffering through the same issue here, kinda, mine leaks at level plug.
    please share what you found works and your refill procedure.
    Thanks
  9. Nov 13, 2023 at 5:56 PM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    I replaced my transmission pan plug crush washers with oil pan plug gaskets (the blue aluminum ones from Toyota). They sealed well, and I have plenty of replacements if necessary next time I service it. Might be a good approach if the crush washers aren’t working for you.
  10. Nov 13, 2023 at 6:30 PM
    bonefish
    bonefish New Member
    Peter
    Just a theory but with crimp side toward pan it digs in and doesn't move. Crimp out toward plug rotates it and bends crimp out of shape. Just changed my 2020 rear diff oil. Crimp washer was original from factory because it had black paint on edge. Both washers had paint and both had crimp toward hole.
  11. Nov 13, 2023 at 8:10 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Your over thinking it. I worked at the dealership level and never was there a discussion on which way the washer went and I never recalled anyone having a come back for a leak. Just use a new one.
  12. Nov 13, 2023 at 10:01 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Ive done 5 drain and fills. Never replaced the gasket, never used a torque wrench and never had a leak. "Tightening it past torque spec" might be your issue, hopefully the pan is okay because getting those bolts out be a pain. Never understood people using torque wrenches on drain bolts, completely unnecessary.
  13. Nov 14, 2023 at 2:56 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Not saying I’m right or wrong about which way the crush washer goes on but I’ll say this: on every single Toyota I’ve ever worked on that never had the trans serviced (meaning came from the factory as such) I’ve ALWAYS seen the crush washers installed on the plug from the factory with the flat side toward the plug. I mean every single one of them. I decided to keep installing them the same way and I’ve never had an issue. Just makes more sense to me is all. The plug has a smooth, flat, machined surface.
    Tundradude2018[OP] likes this.
  14. Nov 14, 2023 at 2:17 PM
    Tundradude2018
    R
    RuggyBuggy and boweavil,
    You asked how I changed the transmission fluid. I did a drain and fill.
    Specifically, I took out the transmission drain plug and let it drain, and put it back in.
    I added back about a half quart more than what I took out into the fill hole
    Started the Tundra and let it warm up.
    I used a laser thermometer a few places on the transmission pan to wait for a temp about 100 degrees.
    Took out the check/test plug and let it spill a bit.
    Replaced the check/test plug and turned off the truck.
    I removed my 5/8" O.D. tube going down through the engine that I used to fill it.
    I replaced the fill plug.
    I learned most of what I ended up doing via this youtube: https://www.youtube.com/watch?v=TH90IJSgg2M
    I have since bought a Scanner with the transmission system loaded, and a live feed. The video I mention above says to wait to take the test plug out until it is in the range from 104-113 degrees.
    I'm open if you have other thoughts though.
    Thanks!
    sask3m likes this.
  15. Nov 14, 2023 at 2:31 PM
    Retired...finally
    I've been using Permatex Anaerobic gasket maker on all my drain plugs. Hell, my Element still had the same crush washer on it after 10 years of oil changes when I sold it. Never had a leak.
    The Tundra gets new every oil change.
  16. Nov 14, 2023 at 10:58 PM
    Joe333x
    Joe333x Member
    Boston
    My engine oil washer has been stuck on the oil oan since my first oil change, I couldn't get it off with my fingers and I wasnt going to chance damaging the pan trying to get it off so it's still there 8+ oil changes later, no leaks, the blue on it is starting to peel though. I have a new one if it ever decides to come off.
  17. Nov 15, 2023 at 6:38 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Take a flat head almost parallel to it and give it a good knock. It’ll come off. I had thought mine wouldn’t budge either during the oil changes after the dealership did them, but it really is just suctioned onto the pan.
    I put a new one on every oil change now, considering how cheap it is on Amazon.
  18. Nov 15, 2023 at 9:39 AM
    Joe333x
    Joe333x Member
    Boston
    It's just not worth the risk to me, If I hit it the wrong way and scratch the pan then it's going to leak with or without a washer and right now it's not leaking so I'm just going to leave it alone, if it starts leaking I'll get it off.
  19. Nov 15, 2023 at 9:46 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    If you're worried about gouging the pan, just use a brass drift, it won't damage anything.
  20. Nov 15, 2023 at 10:03 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Or a plastic scraper
