GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Nov 3, 2023 at 10:26 AM
    #3931
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    I ran 295/70r18 on my stock trd off road. No issues. I assume the sr5 would be the same.
    Troyboy84 likes this.
  2. Nov 3, 2023 at 5:10 PM
    #3932
    GojiraPRO
    GojiraPRO New Member
    2022 White Tundra TRD PRO
    Stock
    Anyone running 295/70/18 Mickey Thompson Baja ATs on their TRD Pro? Currently on my stock rim and tires. Really wanting size 295, Toyos Open Country AT3 are out of stock for a while (Here in Canada and the cost to get them from US is very expensive) But the Baja ATs have peaked my interest and a fair price. Wondering if they will fit fine on the TRD Pro.
  3. Nov 3, 2023 at 5:22 PM
    #3933
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    How are you liking the 1.75" spacer? What brand did you use, and would you recommend it? I'm thinking about doing the same but have heard mixed reviews
  4. Nov 3, 2023 at 9:18 PM
    #3934
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    2024 Tundra Hybrid Platinum
    There's a few people with stock non-Pro's running 295/70/18. But here is a Pro and Plat on them.
    https://www.tundras.com/threads/22-or-23-trd-pro-with-295-70-18-on-stock-18-wheels.114348/
    https://www.tundras.com/threads/what-is-the-largest-tire-i-can-put-on-‘23-platinum.132856/#post-3374805
  5. Nov 4, 2023 at 7:03 AM
    #3935
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I have no problem with the spacer. I had one on my previous truck also for 126k miles with no issues. All it does is give a better stance and a bit more ground clearance. It does not change the ride, contrary to what you might hear from people who repeat hearsay.
    I have the 1.75" Rough Country. It was a perfect level with no more than 1/8" difference between front and back.
    I drive around on land development construction sites every day and it works fine.
    Lebo and Markus[QUOTED] like this.
  6. Nov 4, 2023 at 8:50 AM
    #3936
    Markus
    Mark
    Boring, MO
    A few
    Sold!
    Boerseun[QUOTED] likes this.
  7. Nov 4, 2023 at 1:02 PM
    #3937
    GojiraPRO
    Stock
    TundrX[QUOTED] likes this.
  8. Nov 4, 2023 at 3:50 PM
    #3938
    Markus
    Mark
    Boring, MO
    A few
    One more thing. What did you pay for the install? In not really comfortable doing it myself. Parts are cheap enough
  9. Nov 4, 2023 at 7:26 PM
    #3939
    vichmr
    vichmr New Member
    Scott
    Suwanee, GA & Highlands, NC
    '25 MGM Platinum TRD OR 6.5 w/ factory lift
    Go Rhino Dominator D6, Diamondback HD
    I only found these wheels with a +20 offset (Tire Rack). Where did you buy?
  10. Nov 4, 2023 at 7:41 PM
    #3940
    vichmr
    vichmr New Member
    Scott
    Your truck looks amazing. Do you get much mud, etc. slinging up behind the wheels?
  11. Nov 4, 2023 at 9:29 PM
    #3941
    Boerseun
    Ferdie
    Sarasota Florida
    I don't remember. Maybe $300ish. It is not difficult to install, but a bit tedious.
    You also have to get an alignment done; whatever that cost. I think about $70.
  12. Nov 5, 2023 at 5:19 AM
    #3942
    RedBull
    RedBull New Member
    Boise
    2023 Platinum Hybrid 4x4 Supersonic Red
    Fuel Rebel 18x9, Nitto Recon Grappler 295/70/18, Westcott 2/1 level
    Haven't driven it much in nasty weather but the truck is ceramic coated (System X) so most of the light mud/dirt doesn't stick.
  13. Nov 5, 2023 at 11:42 AM
    #3943
    Flo24TRD
    Flo24TRD New Member
    2024 Lunar Limited TRD Lift
    3” TRD lift TRD Pro grille swap 17” Black Rhino Barricades 35” Falken Wildpeak A/T
    The wheels have 10MM, rubbing front inside frame when I turn hard
  14. Nov 5, 2023 at 4:46 PM
    #3944
    Duckinatruck
    Duckinatruck New Member
    That looks great. I’m getting those same wheels installed tomorrow and I’m planning on getting those same tires due to the ability to go 275/70/18 in an SL instead of E. Have you been happy with the tires and do they perform well on wet roads? Thanks.
  15. Nov 5, 2023 at 6:02 PM
    #3945
    JDak907
    JDak907 New Member
    Well enough, I live in Fairbanks, Alaska so we don’t see a whole lot of rain to give you a real solid opinion. I’ve never lost control on rainy surfaces. They do great in snow / rock / dirt and acceptable on ice.
    Duckinatruck[QUOTED] likes this.
  16. Nov 6, 2023 at 3:28 PM
    #3946
    wraith65
    wraith65 New Member
    Anthony
    2023 Tundra SR5 4x4
    33" BFG K02's Otherwise Stock
    Big Upgrade over the factory SR5 wheels. I picked up the Vision Turbine 18x9 +18 offset wheels at DT.
    With my 275 70 18 BFG K02's it rides so smooth. No rubbing and just a bit of Poke.
    Azrsx, Duckinatruck, TundrX and 2 others like this.
  17. Nov 8, 2023 at 11:21 AM
    #3947
    rajlovermaster
    rajlovermaster New Member
    Jay
    Even I have Sr5 wheels 265 70 R18 and i went to talk to one of the tire shop here to get 18 inch wheel and 275 70 18 Cooper but the the person working there said if you are investing in wheel why not go to 20 inch wheel and install 265 50R20 tires so u can add lift later when u want or add bigger tires....Your set up of 275 70 R18 looks good to me.
    wraith65[QUOTED] likes this.
  18. Nov 10, 2023 at 10:45 AM
    #3948
    brtnstrns
    brtnstrns New Member
    2024 Tundra Platinum HV; 2022 Polestar 2
    Just had SL rated 275/65R20 Nitto Recon Grapplers installed. Hybrid “full electric” mode is definitely not able to keep up as well as it did with stock tires, unsurprisingly, but I’ll have to see how general efficiency goes. They definitely look more correct than the stock tires though.
    Jorts and KClav like this.
  19. Nov 11, 2023 at 4:49 AM
    #3949
    Jrocka
    Jrocka New Member
    2024 Magnetic Gray 6.5 TRD Off Road
    3” TRD Lift, 35’s
    29636768-3249-4B11-8635-722A30064C9F.jpg B73D9B8D-C444-44BE-A800-2034FE1C5186.jpg 2024 6.5 ft bed with 3” trd lift factory installed. TRD 20 rims. Just swapped the sad looking factory tires with some 35x12.5x20 Nitto Ridge Grappler. Slight rubbing at full lock but I think some spacers should take care of that. Or I’ll find away to tuck back the plastic piece that it’s ripping on just a bit.
    Bucng8r, 4lo Toys, Wood-Dro and 6 others like this.
  20. Nov 11, 2023 at 5:55 AM
    #3950
    mricorp
    mricorp New Member
    Is anyone running a 33”X12.5x20? Seems like most want a taller tire but I just want to go wider and try to stay at stock height.
  21. Nov 11, 2023 at 6:25 AM
    #3951
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Put new tires on, 275/65/20 Cooper AT3, changed the chrome lug nuts to black, rides helluva allot better, have the TRD OR kit installed.
    harrybdoyleiv and KClav like this.
  22. Nov 11, 2023 at 6:41 AM
    #3952
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Funny how a simple tire change changes the overall look of these trucks.
    Looks good man!:thumbsup:
    machd08, Boerseun and Jrocka[QUOTED] like this.
  23. Nov 11, 2023 at 10:12 AM
    #3953
    smileytn1
    smileytn1 New Member
    Guess I am old fashioned but I am changing out the 20" Bridges tones on my 2022 tundra limited for raised printed letter continental terrain contact soon they claim to be an 80k tire and made in usa..Anyone in tennessee wana buy the pull offs
  24. Nov 12, 2023 at 10:11 PM
    #3954
    rajlovermaster
    Jay
    Finally pulled the plug...from.stock 275/70R18 to 275/55R20.
    I still have option to go for 33 inch 12 ply radial tires but because of weight I didn't choose that.
  25. Nov 13, 2023 at 3:34 PM
    #3955
    Torque3725
    Torque3725 New Member
    Thorin
    2024 Tundra TRD Pro
    Decked drawers Oct '23 redesign ARE Cap
    Any rubbing ?
    Tundrastruck91 likes this.
  26. Nov 13, 2023 at 4:29 PM
    #3956
    cvd2312
    cvd2312 New Member
    2023 CrewMax SR5 TRD OR
    Are those some type of replica Pro wheels?
  27. Nov 13, 2023 at 5:46 PM
    #3957
    Cfairbank
    Cfairbank New Member
    Kansas City
    2024 Lunar Rock Tundra Platinum
    Dobinson IMS 2" lift, Method 703 17" Wheels, BFG KO2 35"
    Replaced my 2nd Gen Tundra a week and a half ago with a 2024 Platinum in Lunar Rock. Ordered a set of Bronze Method 703's 17-8.5 +35 offset that came in today and had BFG KO2's 35/12.5 put on this afternoon. Wheels and tires fit great with no rubbing or cutting. Dobinson 2" front 1" back lift also came in today however won't be able to install until later this week or next. Diamondback SE Cover is on order. Going from stock wheels and tires made a huge difference. Looking forward to the lift.
    Before
    After
    COTundra23, Txrx, Azrsx and 6 others like this.
  28. Nov 13, 2023 at 10:19 PM
    #3958
    rajlovermaster
    Jay
    Yes...Are these good wheels or they are cheap ,?? I didnt know anything about these until i came back home and searched on google. I kept on asking for moto 0970 but he didnt have it in stock which on phone they told me they had them...
  29. Nov 14, 2023 at 1:08 AM
    #3959
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Looking pretty slick there and welcome to the Dark side my friend!
    Cfairbank[QUOTED] likes this.
  30. Nov 14, 2023 at 6:43 AM
    #3960
    cvd2312
    cvd2312 New Member
    What brand are they and where did you buy them? I’ve never seen them
