TPMS Issue with the new set of rims
Discussion in '3rd Gen Tundras (2022+)' started by 416taco, Nov 5, 2023.
  1. Nov 5, 2023 at 10:40 PM
    416taco
    416taco [OP] New Member
    I purchased a new set of rims + tires for my Tundra, and the vendor installed and programmed the tpms before they shipped the combo to me.
    As per they said, I just simply put the new-built combo on and my truck would pick up the signal.
    But now, after tens of miles driving, the tire pressure light is still on, and there's no message to set it up either.
    Any solution?
    The brand of TPMS is Max,
    Thanks
  2. Nov 6, 2023 at 2:16 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Vehicle setting in the gauge cluster find TPMS and learn sensors keep doing this till it works. I just had this happen to me with my winter set.
  3. Nov 6, 2023 at 6:45 AM
    Tom
    Tom New Member
    Keep driving. Take a while for it to learn.
  4. Nov 6, 2023 at 6:47 AM
    416taco
    may I know how to get the learning option on the dash?
  5. Nov 6, 2023 at 7:21 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    I’ll take a pic when I’m at home but it’s just through the steering wheel controls you scroll through the menu.
  6. Nov 6, 2023 at 9:36 AM
    40man
    40man New Member
    Look at your manual under TPMS.
  7. Nov 6, 2023 at 12:00 PM
    416taco
    thanks, i figured it out already
  8. Nov 6, 2023 at 12:02 PM
    416taco
    no worries, i have figured it out... yea, the vehicle setting under the gear menu
    Yaboy[QUOTED] and GODZILLA like this.
  9. Nov 7, 2023 at 8:59 AM
    416taco
    Hey I tried the method <engine on - door closed - reset tpms on the dash - drive> but the low pressure light is still on.
    May I know how many times you repeated the process before you got it done?
    thanks
  10. Nov 7, 2023 at 10:32 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    I just kept on doing it every time I got in the truck until it didn’t come on. It was lots like 10 times over the weekend, that’s with the OEM tpms I put into my winter set. I dont know what it dose to work but I’ve done that with both sets of wheels and it worked for me.
    416taco[OP] likes this.
  11. Nov 7, 2023 at 11:50 AM
    416taco
    thanks for the hint, didn't expect it's hard for Toyota to learn a new TPMS.....
    Yaboy[QUOTED] likes this.
  12. Nov 12, 2023 at 8:57 PM
    416taco
    problem solved, and endup i had been trying that process 3 consecutive days, and the low pressure light disappeared.
  13. Nov 13, 2023 at 2:24 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Great to hear
  14. Nov 13, 2023 at 3:11 PM
    40man
    40man New Member
    It isn't just learning the codes, it is also learning wheel position. There is no need to go through the process over and over, that will actually take longer. You just need to drive. It has taken as little as 20 minutes and up to an hour for me for it to detect each sensor and wheel position when I have changed tire sets on other newer Toyotas.
    It is actually an awesome feature that avoids buying a Tire programmer/Techstream/Carista or going to a dealer or tire shop to have sensors added.
    416taco[QUOTED][OP] and GODZILLA like this.
