Help! Cali raised OEM switch issue.
Discussion in '3rd Gen Tundras (2022+)' started by Who-V, Aug 24, 2023.
  1. Aug 24, 2023 at 6:00 PM
    Who-V
    Who-V [OP] New Member
    Ontario, Canada
    2023 Tundra Platinum Hybrid Midnight Black
    Rear box step, black chrome exhaust tip, predator steps, box mat
    So I purchased a Cali raised OEM switch to use on my light bar install. I got the bar in switch wired in and working but my dumb ass didn’t make sure the switch would fit. So yeah it doesn’t. The only spot I have available is where the headlight adjustment dial/switch is and it’s just a tad larger than the other switches. Couldn’t tell by eye. So now I have a switch hanging out there. Any ideas if there’s like another part that would allow me to slot this switch into it to make this work?or am I missing a piece from Cali raised?
    The last picture is the dummy that came out. The button (square part) is the same but the rest of the dummy is bigger. It is one piece.
  2. Sep 27, 2023 at 10:41 AM
    Trddride
    Trddride New Member
    Donny
    Trd for life
    Lights, tires,
    Looks like you popped out the frame with it? You figure it out
  3. Sep 27, 2023 at 11:01 AM
    Who-V
    Ontario, Canada
    So yeah I figured it out. That switch frame is bigger you cannot just buy a frame it make it fit. I ended up using an exacto knife and a dremil to cut the protruding square and Dremilled out the opening a little bit bugger to fit the new OEM switch. Turned out nice and tight and you can’t really tell it’s been modified because the button covers the marks. Pain in the ass and stressful but worked. I had ordered a new blank just in case I totally messed it up but didn’t need it in the end.
  4. Nov 13, 2023 at 11:51 AM
    worldinchaos
    worldinchaos New Member
    2023 Sequoia TRD Pro
    You wouldn't happen to have some more pictures would you? This is my only remaining switch blank and I'm thinking of using it for onboard air. Did you basically cut the end and then notch out a place for the detent clips to catch the blank "sleeve"?
  5. Nov 13, 2023 at 12:01 PM
    Who-V
    Ontario, Canada
    Sorry no I don’t have more pictures. I should have taken more while I was doing it. But yes I just cut the button off which is abit of a pain cause the plastic is hard and thick. Then I had to remove some plastic braces that are inside the hollow of the blank. Cleaned it up as best I could then just pushed the switch into the hole in the blank which turned out to be a nice tight fit, no notch needed. It does stick out quite abit further than the other buttons but I’m ok with that. I’ll probably make it better later.
  6. Nov 13, 2023 at 12:14 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Wrong hole
    /thatswhatshesaid
  7. Nov 13, 2023 at 12:17 PM
    worldinchaos
    Thanks for the quick reply. That definitely sounds like more custom work than I was hoping on a visible dash switch. I already have winch power solenoids wired to a Cali Raised switch in another location, so I'll just piggyback the compressor to the same power source as a master cutoff and then install a different control switch locally or use a remote.
  8. Nov 13, 2023 at 12:49 PM
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    You should just get a OEM trd pro light bar switch that goes on that blank space to the left (rectangular cut out)
  9. Nov 13, 2023 at 2:10 PM
    Who-V
    Ontario, Canada
    might try that at a later date.
  10. Nov 13, 2023 at 2:15 PM
    Who-V
    Ontario, Canada
  11. Nov 13, 2023 at 2:24 PM
    TexasTacoma713
    2023 SR5
