Just ordered a pair of Eibach shocks for the rear
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tifford, Sep 11, 2023.
  1. Sep 11, 2023 at 3:21 PM
    Tifford
    Tifford [OP] New Member
    Central New York
    2024 Tundra Double Cab (stock for now)
    Just ordered a pair of Eibach shocks for the rear of my mostly stock 2014 SR. I figured after 147k miles, I'm due for new rears. Toytec was great over the phone.
    I changed the fronts at 100k so there should be plenty of life left.
    Looking forward to getting under the truck and installing them once they get here.
  2. Sep 11, 2023 at 4:32 PM
    Black
    2014 Tundra Limited CrewMax
    Soak that top nut in some KROIL for at least 24 hours before starting and Torch the PISS out of that top nut when you start.
    Had to cut both mine off and only had 75k miles.
    Had to do the same on my buddy’s Tacoma
  3. Sep 11, 2023 at 6:01 PM
    Tifford
    Central New York
    Thanks for the heads up. Liquid wrench gets high marks from a utube channel called 'Project Farm' for stubborn bolts. I'll hit it every evening til the shocks arrive.
  4. Nov 12, 2023 at 12:23 PM
    grumpytundra
    grumpytundra New Member
    Fluid film is a God sent. I everything underneath and in the engine compartment every fall. This stuff keeps everything from rusting and makes it nice when I need to work on something, no nut busting nuts or bolts.
