2020 SR5 new to me
Discussion in 'New Member Introductions' started by DPx2, Nov 12, 2023.
  1. Nov 12, 2023 at 6:40 AM
    DPx2
    DPx2 [OP] New Member
    Picked up a 2020 Tundra with 78k miles. Decided I'd start with the Maint list as I don't think the previous owner did much. Brakes were squealing so I decided to start with those. Rear first, got the lug nuts off and expected the rim to pop right off - nope, seems stuck on. Is this common? Alloy rims. Do I just bang on the rim with a hammer from the inside until they pop off or what? Help!
  2. Nov 12, 2023 at 6:43 AM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    DPx2[OP] likes this.
  3. Nov 12, 2023 at 6:45 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Use a rubber mallet and a bit of PB blaster. That’ll probably do the job. Most likely seized on
  4. Nov 12, 2023 at 6:46 AM
    DPx2
    Mine are disk, the link references drum. First handful of posts (17) on the link all about drum - is it supposed to reference the stuck rim somewhere in that post?
  5. Nov 12, 2023 at 6:47 AM
    DPx2
    Ok, PB Blaster is already on, I'll try the mallet after a bit - Thx
  6. Nov 12, 2023 at 6:53 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Please don't hit your rims with a hammer
    I spray penetrating oil around the lug studs and center hub then use a block of wood against the rim
    DPx2[QUOTED][OP] likes this.
  7. Nov 12, 2023 at 6:54 AM
    It’s actually both. The parking brake is a drum style inside of the discs center hub.
  8. Nov 12, 2023 at 6:55 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Lower your spare wheel, grab it and smack the stuck wheel on the bottom in a swing motion. Clean all oxidation good and add a bit of grease or aluminum-based antiseize (not copper!).
    Leo's first likes this.
  9. Nov 12, 2023 at 6:57 AM
    Leo's first
    Groton ma
    Just curious Whats wrong with copper?
  10. Nov 12, 2023 at 7:00 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    It will cause an awful electrochemical corrosion in aluminum, much worse than steel on copper. If you leave it for a long time and grease dries out, the corrosion kicks in and ruin the wheel. Rule of thumb is to use aluminum antiseize on aluminum.
    Leo's first[QUOTED] and DPx2[OP] like this.
  11. Nov 12, 2023 at 7:04 AM
    DPx2
    I used a block of wood against the rim and it came off - Thanks for all the replies. First Tundra brake job - didn't want to mess it from the get go. I'll probably be back for more advice - TIA
    Leo's first[QUOTED] likes this.
  12. Nov 12, 2023 at 7:04 AM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    Welcome from CO. Just got a 2020 myself.
    DPx2[OP] and Leo's first like this.
  13. Nov 12, 2023 at 8:50 AM
    DPx2
    An absolute to open the bleeder screw to compress the pistons or not? I've seen mention of both....
  14. Nov 12, 2023 at 9:02 AM
    Leo's first
    Groton ma
    I never have unless there is a problem (clogged soft line, stuck piston)
  15. Nov 12, 2023 at 10:14 AM
    Welcome from NY.
  16. Nov 12, 2023 at 11:14 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
