Rebuilt 2005 GX470 Project - From CO to TX and Back (soon)
Discussion in 'Lexus GX Builds' started by M3Tundra-JK, Oct 23, 2023.
  1. Nov 10, 2023 at 8:17 AM
    #91
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    ^^^now that would be a dang good thing to replace,, no fuss no worries! ,,, of course that is after you get all the old ones out. Best of luck!! So far you have been doing all the good!:)
    e30cabrio likes this.
  2. Nov 10, 2023 at 8:35 AM
    #92
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    I'll be damned. I had no idea those were available! I'll have to get some for my MR2, since they're the same size.
    As for the exhaust leak, it seems to not be a matter of if but when - Sequoia, Tundra, GX... no one was safe, haha. In my experience (and backed by research on Ihatemud) it's very subtle and on cold start up, usually going away after it warms up. If you don't have it, then you are definitely one of the lucky ones!
  3. Nov 10, 2023 at 8:38 AM
    #93
    M3Tundra-JK
    M3Tundra-JK [OP] New Member
    Scott
    2005 GX470
    He also has a CEL eliminator on his site, but no pics. Wondering if it's just the spacer, or the signal sender version. Will email him and find out. Else will get these spacers.
    https://jcarpart.com/products/copy-...or-mini-catalytic-converter-o2-sensor-generic
  4. Nov 10, 2023 at 9:05 AM
    #94
    PolishedTRD
    CO
    That would be sweet - would probably work perfect if you go with LT headers. Which reminds me that I misspoke earlier: I had the Doug Thorley SHORT tubes with the old cats welded on. I didn't want have to deal with not passing CO's CARB crap (which didn't matter, because my vehicles ended up getting registered in El Paso County).
    Anywho, let me know if you ever need a hand!
  5. Nov 10, 2023 at 10:01 AM
    #95
    M3Tundra-JK
    Scott
    2005 GX470
    I feel like every bolt is gonna be a fight. Got the front two nuts off the shock tower after several heat/cool/wrench cycles. No idea how I'm going to get the last one off, it's in the center behind everything
  6. Nov 10, 2023 at 10:48 AM
    #96
    M3Tundra-JK
    Scott
    2005 GX470
    Ah ha! Third one is accessible, somewhat, from the engine bay. Will need to remove the airbox on passenger side
  7. Nov 10, 2023 at 3:29 PM
    #97
    M3Tundra-JK
    Scott
    2005 GX470
  8. Nov 10, 2023 at 3:44 PM
    #98
    Black@Blue19
    Ken
    SE Texas
    ^^^^ yup looks toasty!! :). Stop messin around and get that thing on the road!!
    ha I don’t even see toast above!:). Weird
    To busy looking at the pictures
    M3Tundra-JK[OP] likes this.
  9. Nov 10, 2023 at 4:01 PM
    #99
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Man I'm glad I've never had a rust belt vehicle, spoiled by So Cal/AZ cars.
  10. Nov 10, 2023 at 4:05 PM
    #100
    M3Tundra-JK
    Scott
    2005 GX470
    This is my first one. Tbh, had I known about all the rust I would've passed. Last time I'm bidding on a vehicle without going to the yard ahead of time!
  11. Nov 10, 2023 at 7:27 PM
    #101
    M3Tundra-JK
    Scott
    2005 GX470
    F*ck those electronic struts! That metal bracket with the sensor sits on top of the struts and has to be removed before the strut can come down out of the tower. Spent about 2-3 hours just removing the two struts
    Fobroader, RobertD, AZTundra and 2 others like this.
  12. Nov 11, 2023 at 12:41 PM
    #102
    M3Tundra-JK
    Scott
    2005 GX470
    Uh, ya I knew I was supposed to leave the UCA's in for a reason. I meant to break loose all the bolts before actually removing them. Had to reinstall in order to get the LCA lower nuts off. Even had to break out the angle grinder for the passenger side nut.
    e30cabrio and Black@Blue19 like this.
  13. Nov 11, 2023 at 12:43 PM
    #103
    M3Tundra-JK
    Scott
    2005 GX470
    Surprisingly, the brakes seemed pretty good. Lots of material left on the pads, and no grooves in the rotors. It does look like the passenger side caliper is newer than the driver side.
  14. Nov 11, 2023 at 5:40 PM
    #104
    M3Tundra-JK
    Scott
    2005 GX470
    Took way longer than it should have. Had to cut out seized bolts on both sides. But the LCA's are out!
    Going to pick up a needle scaler tomorrow, and get all of the front end rust addressed.
    Have some goodies arriving Monday!
  15. Nov 12, 2023 at 10:06 AM
    #105
    M3Tundra-JK
    Scott
    2005 GX470
    After wire wheeling, looks worse in picture than it actually is. Still haven't found any holes in the frame. One edge of the rotor dust plate is eaten up though. Plan on doing the Tundra brake upgrade or Stoptech at some point and will replace that plate then
    AZTundra, e30cabrio, T-Rex266 and 2 others like this.
  16. Nov 12, 2023 at 10:07 AM
    #106
    M3Tundra-JK
    Scott
    2005 GX470
    Teaser pic lol
    AZTundra, e30cabrio, T-Rex266 and 4 others like this.
  17. Nov 12, 2023 at 1:17 PM
    #107
    M3Tundra-JK
    Scott
    2005 GX470
    Forgot to post the rear bumper cross member outcome. Came out ok. Good test run. Been putting a lot more effort into the rust removal part on the front end.
    Fobroader, AZTundra and Black@Blue19 like this.
  18. Nov 12, 2023 at 2:24 PM
    #108
    Black@Blue19
    Ken
    SE Texas
    ^^^^NICE!!!!:)
  19. Nov 12, 2023 at 4:50 PM
    #109
    M3Tundra-JK
    Scott
    2005 GX470
    Por15 metal prep treatment on the front for 20 minutes. Supposed to keep it wet for that 20. Gonna try and get the front end painted tonight. Takes two coats and 2 - 6 hours cure time between coats.
    Black@Blue19 and AZTundra like this.
  20. Nov 12, 2023 at 5:26 PM
    #110
    M3Tundra-JK
    Scott
    2005 GX470
    After metal prep
  21. Nov 12, 2023 at 6:48 PM
    #111
    M3Tundra-JK
    Scott
    2005 GX470
    First coat freshly on. Giving it about 2 hrs till the next coat. Have heater running in the garage so hopefully that helps
  22. Nov 13, 2023 at 10:48 AM
    #112
    M3Tundra-JK
    Scott
    2005 GX470
    Old vs New UCA's
    RobertD, AZTundra, e30cabrio and 3 others like this.
  23. Nov 13, 2023 at 11:12 AM
    #113
    M3Tundra-JK
    Scott
    2005 GX470
    New vs old LCA's
  24. Nov 13, 2023 at 11:15 AM
    #114
    M3Tundra-JK
    Scott
    2005 GX470
    Por15 second coat went on pretty sloppy. Should have let first coat cure longer. I don't like that it's brush on tbh. Doing touch ups in missed spots with black spay on rust converter.
    Fobroader likes this.
  25. Nov 13, 2023 at 11:16 AM
    #115
    Someone's been chewing on your brake shield.
  26. Nov 13, 2023 at 11:19 AM
    #116
    BeauDacious
    BeauDacious 040 > all other colors
    14 DC 4x
    Impressive amount of work so fast for a project.
    RobertD and M3Tundra-JK[OP] like this.
  27. Nov 13, 2023 at 11:24 AM
    #117
    M3Tundra-JK
    Scott
    2005 GX470
    I'm between jobs atm so I've got a lot of time on my hands lol. Start my new job as Data Center Engineer on Nov 27th. Holding off on naming employer until after I start, but I'm looking forward to it. Been on "vacation" for 1.5 months already
    e30cabrio, T-Rex266, AZTundra and 2 others like this.
  28. Nov 13, 2023 at 1:15 PM
    #118
    M3Tundra-JK
    Scott
    2005 GX470
    Actually I just signed my offer letter. I'm officially a Data Center Engineer 1 at *redacted*!
  29. Nov 13, 2023 at 1:16 PM
    #119
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Whoo hoo! Congrats!
  30. Nov 13, 2023 at 1:21 PM
    #120
    Congrats bud
