KMC, Method vs Icon : Quality/ Durability
Discussion in 'Wheels & Tires' started by Corbic, Nov 3, 2023.
  1. Nov 3, 2023 at 11:41 AM
    Corbic
    Corbic [OP] New Member
    Jack
    '17 Platinum
    Tons of brands out there with all sorts of marketing and influencer hype. Fuel, Rhino, SSW, Vision etc.
    Between KMC, Method and Icon is there any actual difference in general strength and reliability of their cast wheels in the $250-350 range?
    Looking at some sort of 17x9 with a 35x12.5 setup. I could be convinced to go 18's.
  2. Nov 5, 2023 at 3:16 PM
    Corbic
    Jack
    '17 Platinum
    Nobody has ever owned these wheels?
  3. Nov 5, 2023 at 3:32 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    More likely noone has owned all (3) and broken or had a failure from any. I don't think you can go wrong with any, fwiw, I've been running Methods for 10+ years.
    snivilous likes this.
  4. Nov 5, 2023 at 3:33 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I have Method bead grips myself, love them and the look. They are VERY stout and balancing was easy, I did have to torque the fronts in the air though to get rid of a shake. My cousin has some KMC wheels on his Tacoma and hates them, two are bent and one just won't stop vibrating.
    I went with 18's as I had new 18" Yokohamas on some TRD wheels, also I like the 18's as they don't make my tires look like little chocolate donuts.
    Corbic[OP] likes this.
  5. Nov 5, 2023 at 3:34 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I’ve seen cheaper wheels bending pretty easily offroad. But never any Methods or Icons. I’ve only had Methods on my truck and did bend one, but that was probably user error. :D Just don’t buy generic brands if you plan to offroad. Especially if you’re trying to get lightweight wheels.
    NoMoreGreen likes this.
  6. Nov 6, 2023 at 8:17 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Honestly, they all come out select few factories.
    Method wheels are own by Fox (the suspension company) now, and they've always been made in either China or Taiwan, I believe some were made in Philippines.
    KMC is one of brands from Wheels Pros, which owns almost 20 brands , https://www.wheelpros.com/
    Bottom line is, wheels making is rather safe, the process has been refined for a long time and the dividing factor is the Wheels Load index just like your tires they tend to follow JWL standards if they have JWL, means they had it done by a third party, but they can also JWL compliance, means they did their own test but following JWL procedures, Method is typically 3640lb per wheel,
    Wheel Pros tend to go bit higher, which also means their wheels tend to be heavier, they also have a great page explain the way their wheels are labeled:
    https://helpcenter.wheelpros.com/hc/en-us/articles/360055697352-Identifying-Wheel-Markings
    So in our case, forged wheels doesn't always mean better, forged is lighter but its more rigid, which sometimes you want some "softness", kinda like how if you hit a curb, a forged alloy wheel will most likely crack, while steelies will just bend.
    as an example, Vivid Racing Forged is very light, but their load rating is only 2425lbs.
  7. Nov 6, 2023 at 9:28 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I have no experience with Methods and had never heard of KMCs until now. I’ve had Icon Rebounds for about 5 years or so with no problems. I almost got Methods and actually prefer their looks over all the others, but I went with Icons at the time because of their offset and the fact their 17” wheels fit over the large brake calipers.
  8. Nov 9, 2023 at 7:36 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    No issues with my current KMC wheels, and they balance out well. I’ve beat them for over 100K miles with zero issue.
    Down side? They’re heavy. Like OEM wheel kinda heavy.
    I have a new set of SCS Ray10 with tires sitting in the shop, just waiting to finish wearing out my current tires. Hoping to get similar satisfaction from them.
  9. Nov 9, 2023 at 8:37 AM
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    I have method 701s and haven’t gotten to push them hard yet. I’ve been happy so far though.
  10. Nov 11, 2023 at 5:27 PM
    TheBeast
    TheBeast The Beach
    been running my Methods Standard since 2013..no issues to report.
    I recently got some RRW 17's I need to install. time will tell if they are as good.
  11. Nov 11, 2023 at 5:54 PM
  12. Nov 12, 2023 at 5:34 AM
    Black
    2014 Tundra Limited CrewMax
    I have to say give Dustin a shout as well! The fellas customer service and communication is awesome and they make a great wheel.
  13. Nov 12, 2023 at 5:51 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    RRW HH7 on my truck with no issues and method 701s on the old man’s also with zero issues. I’m not sure the type of wheeling you do but any of the mentioned brands should be fine for you
  14. Nov 12, 2023 at 6:47 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Had Methods on zero offset with fake beadlocks for years. I recently bought the Beadgrip 703s, which doesn’t have fake beadlocks, went wheeling and smashed the valve stem. The valve stem broke off part of the rim that it’s seated in, which was not covered my Method’s warranty.
    If you’re gonna wheel, get something that protects the valve stem.
    equin likes this.
  15. Nov 12, 2023 at 6:56 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    But you also had very large stiff valve stems lol
  16. Nov 12, 2023 at 7:02 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    True :laugh:
  17. Nov 12, 2023 at 7:28 AM
    coTony
    Tony
    Montrose, CO
    I run Icons and have never had an issue with the strength of them. I did however have a wheel that had a slow leak (very slow but a leak) for years. It was so slow it did not bother me too much but it was annoying. I finally got a Discount employee's interest and she was determined to find the leak and it ended up being a pin hole in the wheel. It was covered under warranty
    equin likes this.
