Fitting drain tubes with factory bed liner?
Discussion in 'Tonneau Covers, Caps and Shells' started by WVU EERS FAN, Nov 8, 2023.
  1. Nov 8, 2023 at 4:07 PM
    WVU EERS FAN
    WVU EERS FAN [OP] New Member
    Richie
    2023 Tundra Limited
    I purchased a Gator EFX Hard Fold cover & it has drain tubes. I purchased this same cover for a GMC Canyon in past & is pretty simple to install. I have the factory bed liner & it has no access ports, there are the bed drain holes which are smaller than drain tubes. Suggestions for drain tubes?
  2. Nov 10, 2023 at 11:41 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    How much smaller?
    Maybe you could find a piece of tubing to neck it down a step and fit through the drain holes?
  3. Nov 10, 2023 at 1:07 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Step drill bit to open to the necessary size?
  4. Nov 10, 2023 at 2:20 PM
    SD Surfer
    Bruce
    So Cal
    Yep... make the hole bigger, make the tube smaller, pretty much sums uo the options
  5. Nov 10, 2023 at 3:18 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I wouldn't neck down the tube to a smaller one. It will likely clog up a lot sooner.
    What's wrong with running them through the big plastic plugs?
  6. Nov 10, 2023 at 3:31 PM
    SD Surfer
    Bruce
    So Cal
    Yeah, for places with actual rain I'd tend to agree with you. Sorta' depends how much smaller you need to go too.
    I live in San Diego, so the drainage off my tonneau is pretty much car wash, condensation, and that occasional shot glass of rain we get in February.
    When OP said he had factory bed liner, I assumed it to be a drop in that is covering the grommets in your pic.
  7. Nov 10, 2023 at 3:34 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Good catch. I haven't had a drop in liner since my 2011 and didn't think of that.
  8. Nov 10, 2023 at 3:38 PM
    SD Surfer
    Bruce
    So Cal
    Only thought of it cuz my '19 I got last year came with one, so it was in there when I got the tonneau.
    I HATE those plastic liners with a passion.
  9. Nov 10, 2023 at 5:12 PM
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    The 3rd gens dont have that
    NewImprovedRon likes this.
  10. Nov 12, 2023 at 7:08 PM
    WVU EERS FAN
    Richie
    2023 Tundra Limited
    Correct the factory drop in doesn’t have the plastic plugs. Saw a video on YouTube that doesn’t show you installation just the folding back & latching of Toyota trifold. When I bought truck finance guy said Toyota’s were recalled (will fly off). YouTube video has drain tubes going into inner more centered bed drain holes. Probably will have to take my bed rails off to be able to clamp tonneau side rails on. Going to get on this soon before winter comes. Thanks everyone for all your support
