How do I remove trim around front USB ports
Discussion in '2.5 Gen Tundras (2014-2021)' started by rmorse, Nov 10, 2023.
  1. Nov 10, 2023 at 2:25 PM
    rmorse
    rmorse [OP] New Member
    Bobby
    Bowie, MD
    2021 DC Cavalry Blue SR5 TRD Sport 4x4
    Hey guys, trying to upgrade my front USB ports to a UBS C one and I’m having trouble removing the trim. I was following this video https://youtu.be/PX6tIOevlOk?si=m8FhDzVlBC29L8EP and I’m using a straight plastic tool. I’m using WAY more force than he is in the video so I’m wondering if they changed something for 2021 or if I’m doing something wrong. The plastic tool is cracking and it feels like I’m close to breaking something in the dash. Any advice?
    bokch0y likes this.
  2. Nov 10, 2023 at 2:30 PM
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    It's tight. I pulled the trim piece around the shifter to get a little more leverage at the bottom. Once you can get one side to give it will come easy.
    rmorse[OP] likes this.
  3. Nov 10, 2023 at 2:31 PM
    rmorse
    Bobby
    Bowie, MD
    Ok thanks for the tip with the shifter trim piece. I’ll give that a shot tomorrow
    Patch999[QUOTED] likes this.
  4. Nov 10, 2023 at 2:33 PM
    AZBoatHauler
    So.Arizona
    I’ve always had better luck pulling the HVAC panel first. After that the one beneath comes out easy. Grab the control knobs from the top and press down and towards the shifter.
    rmorse[OP] and Patch999 like this.
  5. Nov 10, 2023 at 3:23 PM
    rmorse
    Bobby
    Bowie, MD
  6. Nov 10, 2023 at 3:31 PM
    AZBoatHauler
    So.Arizona
  7. Nov 13, 2023 at 1:51 PM
    rmorse
    Bobby
    Bowie, MD
    Was a busy weekend so I just got back to it. I slapped the new ports in and everything works fine.
    Question though…what switch is supposed to be here? It’s prewired. Is it something I can just buy and slap in?
  8. Nov 13, 2023 at 1:55 PM
    AZBoatHauler
    So.Arizona
    Glass breakage sensor.
    rmorse[QUOTED][OP] likes this.
  9. Nov 13, 2023 at 1:57 PM
    rmorse
    Bobby
    Bowie, MD
    Thanks!
  10. Nov 20, 2023 at 8:50 AM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
