Now that I'm Supercharged what are the Maintenance Requirements
Discussion in 'Performance and Tuning' started by 19PlatinumCrew, Nov 9, 2023.
  1. Nov 9, 2023 at 7:24 AM
    19PlatinumCrew
    19PlatinumCrew [OP] New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    So I was wondering what extra maintenance is required and does it require better antifreeze, higher psi cap,shorter OCI....ect. what if anything have the guys that have been Supercharged for a while done extra.
    Terndrerrr likes this.
  2. Nov 9, 2023 at 7:53 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Why is this a new thread
    snivilous likes this.
  3. Nov 9, 2023 at 9:31 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    snivilous and Terndrerrr like this.
  4. Nov 9, 2023 at 12:18 PM
    19PlatinumCrew
    Dave
    Sorry....moderator can remove it.....
  5. Nov 9, 2023 at 12:18 PM
    19PlatinumCrew
    Dave
  6. Nov 9, 2023 at 1:42 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I’m glad for the thread. Bookmarked it.
    @Saltyhero13’s link will help some of us from having to dig through 400 pages of the general supercharger thread.
  7. Nov 9, 2023 at 2:21 PM
    Saltyhero13
    Personally I just change my oil at 3K intervals but I've considered other mods and upgrades to preserve reliability and longevity.
    I've not seen high engine temps but I also don't tow heavy, mostly haul gear nor do I drag race my truck.
  8. Nov 9, 2023 at 2:28 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    I searched for, "maintenance" within the s/c thread and found results within seconds.
  9. Nov 9, 2023 at 2:45 PM
    Saltyhero13
  10. Nov 9, 2023 at 4:35 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    Mine has only been supercharged for 16k miles/2 years, but happy to share my thoughts on maintenance FWIW. I like a 3-5k OCI using 5w30 instead of 0w20. It’s probably also wise to keep up with the fluid changes on the diffs, transfer case and transmission. I’m gonna try to stick to 30k intervals on those personally. Keeping the coolant fresh too is also probably beneficial since the engine will generally be seeing higher heat.
    Other preventive measures that might help are a catch can on the PCV, and changing out your serpentine belt more often since it’s under more stress with spinning the blower. Spark plugs will also probably need to be changed more often. I’m thinking every 30-40k for the plugs now. This is based on nothing scientific other than they are likely to get fouled more quickly with the boost and rich mixtures. I also went a couple steps cooler on plugs (Denso IKH24s), not sure if you did colder plugs as part of your install or not. 1 step colder would be IKH22s I think.
    Also, sorry to say your tires aren’t gonna last as long!
    :burnrubber:
  11. Nov 9, 2023 at 4:53 PM
    Wallygator
    Severe duty schedule for sure! It’s in the owners manual. I’m not supercharged and it’s what I follow. YMMV
  12. Nov 9, 2023 at 10:46 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Also during summer I run 5w40 and winter 5w30. Run cooler spark plugs ikh 24 gapped at .021 for 10+ psi.
  13. Nov 10, 2023 at 2:14 AM
    Rear tires every 10-15k miles.
    Saltyhero13 likes this.
  14. Nov 10, 2023 at 3:20 AM
    Adam New Member
    Thanks for letting everyone know.
    19PlatinumCrew[OP] likes this.
  15. Nov 10, 2023 at 4:40 AM
    19PlatinumCrew
    Dave
    We spend untold amounts on our trucks,just looking to keep it running for at least 200k thanks for all the responses
  16. Nov 10, 2023 at 5:58 AM
    Terndrerrr
    Music City
    6UR-FE
    If I follow through with this, I bet my first set doesn't last that long.
    Mdl and Saltyhero13 like this.
  17. Nov 10, 2023 at 6:31 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I do literally nothing different. About to hit 300k.
