1.75” or 2” level kit on 295/70/18
Discussion in '3rd Gen Tundras (2022+)' started by dbill7, Nov 9, 2023.
  1. Nov 9, 2023 at 5:21 PM
    dbill7
    dbill7 [OP] New Member
    Hey there I’m torn on either the 1.75 or the 2” I really don’t want the front end to be to high I want it to sit nice and level the wescot 3/1 just looks to big for my liking with the 295.
    I’m running 295/70/18 starting to wish I would have went 35/12.5
    anyone with this set up and +18 offset?
    That is my next step to get rid of the terrible factory rims.
    Let’s see some pics of this set up
    Your help would be great
    Troyboy84 likes this.
  2. Nov 9, 2023 at 5:27 PM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Go with Cornfed option1.5. The others will be nice high for sure.
  3. Nov 9, 2023 at 5:38 PM
    socaldad
    socaldad New Member
    23 SR5 crewmax TRD-sport
    I’m in same boat, I have trd sport. I’m undecided between 1.5 or 1.75” for 275/65/20.
  4. Nov 9, 2023 at 5:48 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I did the 1.75” up front then a 1” in the back. Ride is good and I like the height
  5. Nov 9, 2023 at 5:56 PM
    dbill7
    Do you have any pictures ?
  6. Nov 9, 2023 at 6:02 PM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Here’s cornfed 1” front with 295’s. I think it sits nice. I’m not a fan of the nose high look.
    socaldad and dbill7[OP] like this.
  7. Nov 9, 2023 at 6:11 PM
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    1.75” front. 1” rear. 295’s.
    IMG_5218.jpg If you don’t lift the rear I’d go with 1” Cornfed up front. Otherwise they look nose high.
    Yaboy likes this.
  8. Nov 9, 2023 at 6:12 PM
    cvd2312
    cvd2312 New Member
    2023 CrewMax SR5 TRD OR
    I have the Cornfed 2” front/1” rear. Still on stock tires but will go to 295 when they wear out
    Keeptipsup52 likes this.
  9. Nov 9, 2023 at 6:30 PM
    dbill7
    That’s looks great I have never heard of these corn fed lifts. I really like the look of the 2/1
    How is the ride? Are they a preload like wescott?
  10. Nov 9, 2023 at 6:51 PM
    Northern Toyota
    Tires and bilstein
    My 1” is a 0.5” thick spacer that goes on top of the coil over assembly. Not pre load. No difference in ride quality. That comes from E load tires.
  11. Nov 9, 2023 at 6:55 PM
    Yota802
    Yota802 New Member
    I agree, the 1.75 will definitely sit nose high. Mine did…added 1” to the back. Looks good, but if I did it all over again, I’d go 1” Cornfed in the front.
  12. Nov 9, 2023 at 7:13 PM
    cvd2312
    cvd2312 New Member
    The guy at Cornfed is great. Ride quality is on par with stock, I’d say I can feel it a bit when I hit bumps but that’s it. It’s a bottom preload spacer combined with a small 1/4” top plate shim. The rear is just a spacer that sits above the coils.
    I installed myself, it was pretty easy.
  13. Nov 10, 2023 at 7:07 AM
    TundraMoe
    Agree!
  14. Nov 10, 2023 at 7:19 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Here is mine after the 1.75 front lift.
    It was pretty level but I found it was too squatty with the trailer on so I added the 1" rear spacer and it solved that.
    I don't have any recent pics of the current setup but just picture a tiny bit of rake!
    Black widow TRD and dbill7[OP] like this.
  15. Nov 10, 2023 at 8:19 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    2/1 Cornfed
    socaldad likes this.
