Center Console Safe/Lock Box
Discussion in '3rd Gen Tundras (2022+)' started by Tusa123, Nov 7, 2023.
  1. Nov 7, 2023 at 10:37 PM
    Tusa123
    Tusa123 [OP] New Member
    I’ve been wavering on the OEM Toyota console safe but the combo knob looks cheap and the other combo options out there suck equally and are just as expensive.
    I found this inexpensive option on Amazon and bought it hoping the existing hole would be standard tube cam lock, good news, it is! There are a number of alternative lock options to fit that hole from barrel key, electronic, etc. so $120 (safe) + $10-$100 (lock) you’re still about $200 cheaper than OEM.
    https://a.co/d/6Ixtr6V
    https://www.amazon.com/dp/B01D3LROZ6
  2. Nov 8, 2023 at 2:07 AM
    911turbo
    911turbo New Member
    Those safes are terrible. The locks are terrible. The numeric roll is awful. Get yourself the oem box. It’s very good. Can often find them used on Facebook marketplace for 100-200.
    Soflo likes this.
  3. Nov 8, 2023 at 2:21 AM
    tundramh
    tundramh New Member
    OHIO
    What are people using these for when the truck is locked up? You still get a broken window. I had one in an old wrangler but that's because everything was easily accessible. Do I get one of these only because it's an available accessory?
  4. Nov 8, 2023 at 2:28 AM
    AggiePhil
    College Station, TX
    FAS1 Safe is the answer you seek. That is all.
    Tundrastruck91 likes this.
  5. Nov 8, 2023 at 2:33 AM
    911turbo
    911turbo New Member
    I use it as a temporary gun safe when parked.
    Soflo and Blufin like this.
  6. Nov 8, 2023 at 3:37 AM
    pursuit2550
    pursuit2550 New Member
    I have the OEM safe in my 2020. I can say that it's well worth the money. Has number and key lock. Mine came installed from Toyota in my configured model. I have no experience with the Amazon safe. I would be weary like another member stated.
  7. Nov 8, 2023 at 5:20 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
  8. Nov 8, 2023 at 8:39 AM
    Tusa123
    Tough crowd. 911turbo the point was to ditch the lock and replace it with a better quality one. I don’t need an impenetrable safe. I need something to keep my firearm accessible but safe from the kids and snatch n grabs. If I need to park long term I have a much more secure safe under the seat. But that’s not really accessible or realistic to grab each time. This was just a far cheaper option to accomplish what I need than spending $400 with Toyota.
  9. Nov 8, 2023 at 1:46 PM
    911turbo
    911turbo New Member
    I initially purchased the one you linked and had to return it. Quality wasn’t there for me. I found a slightly used Toyota oem safe for $100 and it works perfectly. Much better route.
    tundznoff likes this.
  10. Nov 8, 2023 at 2:13 PM
    Bailey1794
    Bailey1794 New Member
    Houston
    2023 Smoked Mesquite Hybrid 1794 Tundra
    Diode Dynamics Ambassador & Talons Garage Affiliate (See Below for discounts) Use code Bailey for Diode Dynamic free shipping Current Build & Pics Instagram.com/Bailey1794 Discounts & Affiliate links below https://linktr.ee/bailey_1794?fbclid=PAZXh0bgNhZW0CMTEAAaYH-pwfNz76E_oAQekLat2ZdcSY0VrV7a8O3_UxaU15mlBifUGV3lGaU4s_aem_Aamyw5XakyTlp6h_WyGSA8wBSO-cFzK1Z0t3EQBBaXEgDCnQI49fSwGFqQNWOCNd5OxDNGhVrMYRcfs_DEuuCXSy
    i would go with the OEM takeoff over the Amazon safe.
    Soflo likes this.
  11. Nov 8, 2023 at 2:29 PM
    Tusa123
    It sounds like OEM is the way to go here. Does anyone have any issues with the dial? When I’ve had these in prev trucks the dials were sticky and highly inaccurate. I think that’s why I’m hesitant to go with OEM but more and more it sounds ok.
    To that end, anyone want to sell me theirs?
  12. Nov 8, 2023 at 11:26 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    The OEM safe is not even enclosed on all sides. Anyone can just pry it out of the plastic console with a crowbar or large flathead breaking through. It’s not a surefire way to protect something; it’s just to reduce smash and grabs that don’t have effort put into them.
    No issues with dial, works fine. Put your insurance/registration in there so thieves don’t just easily have your registered address and info.
  13. Nov 9, 2023 at 9:27 PM
    Tusa123
    Thanks for all the responses. Quick update for future viewers and to close out this thread.
    The kind folks on this thread were correct. I found and have installed the OEM safe and it’s made much better than I thought it would have been. The dials on the combo are crisp and don’t float around. The barrel lock is equally high quality. This isn’t Fort Knox but for $100 used it’s certain to accomplish my goals for it.
    If someone wants what’s in it they will get in. It’s a 3 digit combo…This is perfect for those smash and grab scenarios. One note, if you’re locking up some coins and a $30 set of sunglasses just leave them out and leave the safe unlocked. If someone wants into the safe they will have to tear apart your center console; I can’t even imagine the cost to repair.
    Thanks again y’all!
  14. Mar 6, 2024 at 6:15 AM
    BlueCrushSC16
    Charleston, SC
    I just pulled the trigger and went with the console vault. Someone mentioned in another thread that it was better for the higher trim models with the sliding tray. FYI, Console Vault offers a 10% discount for military and first responders.
  15. Mar 6, 2024 at 4:31 PM
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Locker Down Safes
  16. Mar 6, 2024 at 9:48 PM
    tundznoff
    tundznoff New Member
    blk limited tundra
    TRD red axel swap Satin black wrapped fender flares Satin black wrapped bumper insert Icon stage 5 Icon 1.25 rear spring Drkdss panhard bracket Rave trd pro grill & lights 37” K02 17” 0 offset Nomad Sahara
    I have the OEM safe but I bought it used from dealer and don’t have code however I have the key.
    is there a way to find out the code or over write it with the key ?
