  1. Nov 6, 2023 at 4:41 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Replaced the air filter and cabin filter. Here is a pic of the cabin filter. Air filter was not as bad. I'm thinking about tackling the spark plugs, but a couple look to be tricky to access, so not sure I want to do this myself.
  2. Nov 6, 2023 at 4:45 PM
    Droptarotter
    Droptarotter New Member
    2020 Tundra TRD Off Road, Double Cab
    Today;
    Checked the brakes.
    Adjusted park brake.
    Tires rotated.
    Checked diff and transfer case oils. Transfer case needed a bit.
    Tried to get the oil filter off, but all my oil filter tools are not good enough so need to order a good filter tool.
    Installed a higher rear diff vent hose just in case I have to get the rear into the water to launch/retrieve the boat.
    Built a console divider out of some plastics I had laying around.
    Cheers
    Velocity72, bulldog93 and Wallygator like this.
  3. Nov 6, 2023 at 5:29 PM
    centex
    centex New Member
    You asked for something custom, they said no, and you are upset about it. About sum it up?
    Just because it’s a door to you doesn’t mean it’s not enough of an undertaking for them to make it not worth it, even if they do charge you more. Custom isn’t always worth the hassle.
  4. Nov 6, 2023 at 5:38 PM
    WodenTX
    WodenTX New Member
    Duke
    Saint Johns, FL
    2015 Black 1794
    I put in a set of LASFIT Switchback fog lights, replacing the old halogen bulbs in my 2015. Holy crap what a difference they make! Now I need to order me some 2021 head lights.
    bulldog93 likes this.
  5. Nov 6, 2023 at 6:40 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    [/QUOTE]
    What's your wheel and tire setup? That looks amazing!
    Leek128[QUOTED] likes this.
  6. Nov 6, 2023 at 8:16 PM
    Wallygator
    Place is a rip off IMO. Ridiculous prices! Crazy what people will pay for convenience. I’m in the process of building a platform myself. Looking to get it all done for less than $250. In this case it is worth the inconvenience to diy, again IMO.
    coTony[QUOTED], Tundra234 and SAGE63 like this.
  7. Nov 6, 2023 at 8:23 PM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    The driver's side plugs are easy. The passenger side plugs by the firewall are easy once you move the interference in front of the plugs. That's a simple task that only required the removal of some mounting bolts and pulling the wires out of the way. I think I looked it up on YouTube University and found a guy that showed where the interference was and how to get around it. Replace the coil to plug boots while you're in there. Don't be afraid or intimidated by this one. You got this!
  8. Nov 7, 2023 at 5:10 AM
    Gecko.
    Gecko. New Member
    CT
    2014 Tundra DC
    Thanks for posting. Wow, that's impressive. Been trying to decide between the Pro and the Max (i.e., whether the extra coin for the Max is well spent).
  9. Nov 7, 2023 at 5:10 AM
    DirtyMike5
    DirtyMike5 New Member
    Baton Rouge
    My process so far on these wheels, I need advice on how to proceed with painting the "ring" black. Masking off and spraying would be the best bet, but has anybody attempted hand paint?
    So far, I'm two weeks in and I'll give the paint job a 8/10. A few paint heavy spots but I think it'll hold, would like to add the black ring next and then find some new tires (285/75r18)
    Screenshot_20231024_103419_Facebook.jpg 20231027_100640.jpg 20231029_175709.jpg 20231104_135003.jpg 20231105_112942.jpg 20231105_112948.jpg
  10. Nov 7, 2023 at 5:15 AM
    DirtyMike5
    Baton Rouge
    Here's a mockup.
    mgm16trdpro and CaptRussia253 like this.
  11. Nov 7, 2023 at 5:41 AM
    AndyTex
    AndyTex New Member
    2020 Tundra 1794 4x4
    Came up on 3 year mark and flushed the brake system with ATE Typ 200 using Speedibleed https://www.speedibleed.com/. Speedibleed made bleeding an easy task. Brake fluid came out fairly clean and not dark at the calipers.
  12. Nov 7, 2023 at 5:44 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Great question. I didn't remove any white branding. Now you have me second guessing them. I'll check it out when I go out on lunch and report back.
  13. Nov 7, 2023 at 8:23 AM
    WSDMetal
    WSDMetal Motorsports Fabrication & Design
    Huntington Beach
    Pulled the trigger on some @RCIoffroad aluminum skid plates after some bozo on Facebook tried to rip me off on a used transmission skid sale with missing hardware and bracket.
    I believe their Black Friday Sale is on now if anyone is looking for a deal on some super beefy, well made skid plates.
  14. Nov 7, 2023 at 9:55 AM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    I have so much stuff that’s been sitting around needing to be installed from last Black Friday . I moved a state over and my second son was born so lots has happened.
    Here’s what I got done today: Royal tow hooks in red and Diode Dynamics hitch light with locking pin.IMG_2206.jpg IMG_2208.jpg IMG_2209.jpg IMG_2121.jpg
  15. Nov 7, 2023 at 3:43 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Ok, for those of you that run EBC pads, did you guys reuse the shims or used the piston shim that came with the EBC pads? My rear ended up being stupid corroded and I was trying to see if local store had it, but if I do need it, I’ll have to go to the dealership tomorrow.
    Fronts are done with EBC yellow stuff and SDHQ SS lines.
    Also, for those of you that ran SDHQ SS lines, is this the proper placement for the copper washers?
  16. Nov 7, 2023 at 4:10 PM
    WBW
    WBW Resident lurker
    Bruce
    Yes, that is where the copper crush washers go.
    pvn.beluga[QUOTED] and bulldog93 like this.
  17. Nov 7, 2023 at 4:14 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Happened to see the vendor in another thread just now. I couldn't get a configurator to give me the product without the molle option, so I'm not sure if it'll fit your needs, but thought I'd share.
    SHW OFFROAD 2.5 Gen Tundra Seat 60% Seat Delete-Optional MOLLE Back Wa – Artemis Overland Hardware
  18. Nov 7, 2023 at 4:28 PM
    coTony
    Tony
    Montrose, CO
    Butthurt is the fucking word I guess you can say
  19. Nov 7, 2023 at 9:38 PM
    donWeb
    donWeb New Member
    Tony
    2018 SR5 DC 5.7
    Added color matched handles.
    Removed chrome door badge.
  20. Nov 7, 2023 at 10:58 PM
    Leek128
    Leek128 New Member
    Bucks PA
    What's your wheel and tire setup? That looks amazing![/QUOTE]
    Thanks. 275/70/18 duratracs on factory pro rims.
  21. Nov 7, 2023 at 11:46 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
  22. Nov 8, 2023 at 5:57 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Actually, found out that the factory shims aren’t supposed to be used and to use whatever shims that came on those pads…
    NewImprovedRon likes this.
  23. Nov 8, 2023 at 11:06 AM
    coTony
    Tony
    Montrose, CO
    I need to look at the center console and see if I can just get the rear window switch to pop into a hole I make in the console. I have not seen any single gang switch mount so I figured I better do something since I cannot roll my window down now. LOL
  24. Nov 8, 2023 at 1:43 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Finished installing all the rotors, pads, and lines. Break in was 60>10 about 8-9 times before trac off started beeping. Went away a couple minutes later.
    The rotors look pretty even throughout.IMG_5564.jpg IMG_5565.jpg IMG_5566.jpgIMG_5567.jpg
  25. Nov 8, 2023 at 1:49 PM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Tundra-XP, espdtrd, Jego and 20 others like this.
  26. Nov 8, 2023 at 2:01 PM
    Xcumminsguy[QUOTED] likes this.
  27. Nov 8, 2023 at 2:26 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    My OE rotors were shot at about 30k, but the shuddering wasn’t too bad until recently. Seemed to have gotten my use out of my OE rotors and pads after 3 years of ownership.
    Rears were still good.
    Also changed out engine air filter with WIX and cabin filter.
  28. Nov 8, 2023 at 3:50 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    IMG_8485.jpg Found my trucks cousin yesterday
  29. Nov 8, 2023 at 5:04 PM
    bfunke
    bfunke Tundra Curmudgeon
    Are they same color? Tundra looks lighter shade.
  30. Nov 8, 2023 at 6:40 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Met up with a buddy of mine
