2018 Factory LED Headlights Cloudy?
Discussion in 'Lighting' started by DanTundra, Nov 6, 2023.
  1. Nov 6, 2023 at 6:50 PM
    DanTundra
    DanTundra [OP] Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    I replaced both of the headlights on my 2015 Tundra with the TRD 2018 LED versions with the harness and they've been night and day difference. However, I've started noticing what appears to be a cloudy haze on the inside of the driver's side lens. I don't see any signs of moisture and I'm 98% certain the haze is on the inside of the headlight.
    It's only at the bottom of the lens, and that wasn't like that when I installed them.
  2. Nov 6, 2023 at 10:30 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    gotta be a leak of some sort
  3. Nov 7, 2023 at 5:10 AM
    Make sure you have a good bulb seal. Maybe even replace them to rule it out.
  4. Nov 7, 2023 at 6:25 PM
    DanTundra
    Wilmington, NC
    I'll check all the bulbs tomorrow. Its weird because I've NEVER seen moisture..just this cloudiness and it's always at the bottom of the lens 24/7.
  5. Nov 7, 2023 at 9:06 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Definitely looks like moisture is getting in. Just a tip while you’re figuring it out - keep it out of direct sun. The moisture will dry too quickly and it will haze over inside the light.
