Dreaded 4wd blinks for several miles
Discussion in 'General Tundra Discussion' started by Flhtc, Nov 7, 2023.
  1. Nov 7, 2023 at 8:27 AM
    Flhtc
    Flhtc [OP] New Member
    Paul
    2004 Tundra
    None
    Hello everyone and thank you for allowing me to join this group.
    I recently bought a 2004 Tundra SR5 TRO with a double cab and 160,000 miles on her. The truck was incredibly clean for being in Massachusetts, hardly any rust and no rot.
    My 4X4 high light blinks for several miles then the light will stay on. Truthfully, I’m not sure if the 4-wheel drive is engaged while the light is blinking. Could this be more of a vacuum issue?
    Thanks
  2. Nov 7, 2023 at 10:23 AM
    Welcome aboard sir! Sorry to hear about your 4wd troubles. There is no vacuum activation for the 4wd system, all electric. You may be having problems with the electric actuators. If not used regularly they can become corroded and non-op. Good idea to use it at least monthly. When the light is blinking, the system is not recognizing the truck as being in the 4wd state selected.
    Flhtc[QUOTED][OP] likes this.
  3. Nov 7, 2023 at 2:22 PM
    bonefish
    bonefish New Member
    Peter
    Treasure Coast Florida
    Change the Transfer Case fluid?
    Flhtc[OP] likes this.
  4. Nov 7, 2023 at 2:31 PM
    Flhtc
    Paul
    2004 Tundra
    None
    I’ll do this right away, thank you.
  5. Nov 7, 2023 at 5:33 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
