*** COILOVER DROP AT TOYTEC ***
Discussion in 'Suspension' started by Toytec Lifts, Aug 29, 2017.
  1. Aug 29, 2017 at 10:29 AM
    Toytec Lifts
    Toytec Lifts [OP] New Member
    Denver, CO.
    Hey guys!!
    Here we go again with a new coilover drop for you Tundra guys!!!
    We have a basic front coilover setup for the 2nd Gen Tundras, 3'' solid lift, no adjustments, just slap in and forget about it. Easier for those people that don't want the adjustable setup!!!
    Link: http://toyteclifts.3dcartstores.com...nt-Coilovers--3-Lift-07-15-Tundra_p_1825.html
    Description:
    TUNEBCS - Toytec/Eibach Complete Front Coilovers - 3" Lift
    • Take your truck performance to the next level.
    • Eibach PRO-TRUCK Sport Shocks are Made in the USA and built to last using a Monotube Design with 46mm Pistons, Larger Nitro-Coated Rods and Heavy-Duty Durable Zinc Coated Shock Bodies
    • Eibach Pro-Lift Coil Springs - Front Lift coils are designed to increase ground clearance, for better off-road clearance and performance. The added suspension travel delivers a more responsive, more controlled ride over rough terrain, and gives you the additional wheel-well clearance to use bigger, higher-performance off-road wheels and tires.
    • Legendary Eibach Ride Quality
    • High Performance Handling & Stability—On or Off Road
    Includes:
    • Eibach Pro Sport front shocks
    • Eibach front Pro-lift front coils
    • Fully assembled with new top mounts and Urethane bushings.
    • Ready to install, no spring compressor needed.
    • Sold as a pair
    • Fits 2007-2015 Tundra
    • Provides approximately 3" of lift - (3" average lift is achieved with coils and setting the shock adjustment on the 2nd C-clip setting) Use of top setting to get more than 3" of lift may cause damage and is not recommended.
    *Note: Average lift measurements are based on a stock vehicle with no added aftermarket accessories or additional weight.
    Any questions let me know!!!
    -David
    yoshi82, Patriot, MTwiford and 5 others like this.
  2. Aug 29, 2017 at 10:40 AM
  3. Aug 29, 2017 at 10:59 AM
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    Price is for a set if 2? Also would this be considered an upgrade from 5100 s and stock Tundra Springs? Thanks Marc
  4. Aug 29, 2017 at 11:39 AM
    Toytec Lifts
    Denver, CO.
    Hey Marc,
    Yes sir these are priced per pair!!!
    Would be a great upgrade over what you have now!!!
    PM me if you have any questions!
    -David
    Law323 likes this.
  5. Aug 29, 2017 at 11:44 AM
    kicnit
    kicnit New Member
    14 Tundra TRD DC
    De-badged
    How many clip settings are on these shocks? I know there's a highest setting that mentions it's not recommended, but is there a lower setting, closer to 2" as well?
    Thanks
    Kyle
    Toytec Lifts[OP] likes this.
  6. Aug 29, 2017 at 11:48 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  7. Aug 29, 2017 at 11:49 AM
    Toytec Lifts
    Denver, CO.
    ***** EDIT *****
    Hello Kyle,
    There are 3 clip settings on the shocks themselves but we highly recommend sticking to the pre-set clip setting for best ride quality and overall longevity of the suspension.
    Just spoke to manufacture and the bottom clip setting will yield closer to 2'' of front end lift. We would not be able to assemble them, we do offer springs and shocks by themselves if wanted.
    We have not tested the lowest clip setting so at this time I can not say how much lift it will yield.
    -David
  8. Aug 29, 2017 at 12:18 PM
    A great deal for sure and preassembled.
    Toytec Lifts[OP] and TheBeast like this.
  9. Aug 29, 2017 at 12:56 PM
    be77solo
    be77solo New Member
    2017 Silver Crewmax 4x4 5.7L
    KO2's on ENKEI ST6's, BakFlip MX4
    Hey, quick question, these look nice for the price.
    Why are some of your coilovers listed for 07 and up, and these are 07-15? Curious what was different.
    Thanks!
    Toytec Lifts[OP] and strosek7 like this.
  10. Aug 29, 2017 at 1:13 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Law323 and GNTundra like this.
  11. Aug 29, 2017 at 3:13 PM
    Stig
    Stig New Member
    Can you elaborate how these differ from 5100s and the OEM springs?
    GNTundra likes this.
  12. Aug 29, 2017 at 3:21 PM
    Toytec Lifts
    Denver, CO.
    The reason being we state that 07-15 is because the 16+ have a little bit of a different coil spring rate (stock) so we are not 100% sure what the ride height will be quite yet.
    Stay tuned!
    So the Bilstein shocks do offer a Digressive valving in the shock as to the Eibach's have a progressive style valved shock with a coil spring that is built around/ specifically for that shock.
    The Bilstein shock+ OEM coil spring will only yield 2.25'' of front end lift, preloading the OEM coil spring or manipulating it to a different coil rate to give you lift will reflect in firmer ride quality especially with digressive valved shocks, and you will be loosing travel with a pre loaded coil spring.
    The Eibach coilovers will be built at the middle setting of the shock, giving full range of travel within the shocks limits, along with a larger/ taller spring with a heavier spring rate will reflect in better ride quality and performance both on and off the road.
    -David
  13. Aug 29, 2017 at 3:29 PM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Can you tell us the specs on this set-up. Specifically, I would be interested to know the following:
    Coil spring rate
    Coil spring length
    Difference between extended length and the total collapsed length of the shocks.
    I am curious to see how they compare to something like the OME set-up.
    By the way, I got 3.5 inches with the OME 614 in the front without manipulating anything.
    Black Wolf likes this.
  14. Aug 29, 2017 at 3:33 PM
    Ditto. I have at least 3" lift with my OME with 614 coil and 100lb Ranch Hand hanging on...
  15. Aug 29, 2017 at 3:36 PM
    Can't go wrong with the Eibachs' but prefer my OME ToyTec setup. Thanks again ToyTec!!
    T-Rex266 and Law323 like this.
  16. Aug 29, 2017 at 3:43 PM
    It's nice to see another quality budget friendly coilover setup offered from ToyTec. Definitely a notch up from the Bilsteins IMHO.
    T-Rex266 likes this.
  17. Aug 29, 2017 at 3:49 PM
    JerseyTundra1260
    Marc
    New Jersey
    Nice..plus a little more lift :thumbsup: Would these pair up with SPC Uca's well you think?
  18. Aug 29, 2017 at 3:51 PM
    Of course. If I'd stop buying tires and batteries..the SPC's are next. Maybe I can win a pair in ToyTecs next customer appreciation day raffle........
  19. Aug 29, 2017 at 3:52 PM
    be77solo
    be77solo New Member
    OK cool, thanks for the follow up. Curious what the difference ends up being. Very interested in this option for my '17, as I'm not interested in adjustable.
    Will these be just fine alignment wise with stock UCA's?
  20. Aug 29, 2017 at 4:00 PM
    Close but no cigar. The SPCs will fix that.
  21. Aug 29, 2017 at 4:06 PM
    be77solo
    be77solo New Member
    Close like barely in spec or close but won't drive quite right? Did 2.5" on my 4Runner 5th Gen without UCA's and it never quite felt "right".
    Was hoping the Tundy could handle it ha
  22. Aug 29, 2017 at 4:10 PM
    It's hard to get perfect alignment. You end up with almost perfect. Not a huge deal. Remember after all you are changing OEM geometry. There is always going to be some give and take. Upgrading the UCAs brings you back to the ideal alignment.
    JerseyTundra1260 likes this.
  23. Aug 29, 2017 at 4:17 PM
    be77solo
    be77solo New Member
    But, if I add your mythical brake pads from other thread I seconded it is magically perfect though? I gathered that from other thread....
    :rofl::rofl::rofl::thumbsup:
    Thanks for info, was hoping to save the cash but seems like they are worth it. I know in hindsight before the tree crushed my 4Runner I wished I had them. I'm still not convinced the shop did a proper alignment though.
  24. Aug 29, 2017 at 4:18 PM
    There will be folks chiming in soon enough like our two Mods who have completed thier setup with SPCs and beyond.........$ like Total Chaos for example. All about your money tree. SPCs are budget friendly and very good. There's always better. Depends what you do with your Tundra. Ask jberry. Resident forum suspension guru along with ColoradoTJ.
    be77solo likes this.
  25. Aug 29, 2017 at 4:22 PM
    Definitely go with my mythical brake pads. Can't go wrong....I swear....
    be77solo[QUOTED] likes this.
  26. Aug 29, 2017 at 4:24 PM
    You did get pissed off and take a chain saw to that tree and turn it into kindling...I hope....
  27. Aug 29, 2017 at 4:32 PM
    If you get the Eibachs' ....get the diff drop too. Not really needed but easy to install and quite frankly a good thing to do.....
  28. Aug 29, 2017 at 4:56 PM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    I may be interested in being the guinea pig on a set of them at the bottom setting (if they are indeed at the 2" mark).
    I'm honestly surprised no manufacturer makes an even 2" front coilover or regular bilstein 5100 type adjustable shock with a 2" mark designed specifically to level out a 2nd-3rd gen Tundra without having to add anything in the rear. Seems like there would be a huge market for it for the guys who want level without going up to a 3/1.
    I'd be first in line.
  29. Aug 29, 2017 at 5:02 PM
    be77solo
    be77solo New Member
    Still pissed at that damn tree.... loved my Trail!
    But, the frustrating road led to a Tundra, so can't complain a year later after a short stint with a Tacoma :thumbsup:
    Thanks for the tips on the UCA's, definitely want it to align and drive properly when finished. Don't need anything fancy, just an honest good driving 3" lift. Mostly on roads, but in construction so haul/tow and navigate land/new lots regularly as well.
  30. Aug 29, 2017 at 5:09 PM
    Big ass tree....It's always good to look for that silver lining....glass half full. Like the folks in south Texas need to do....Those Texans (like me) are showing the world their "grits".
