Fluid change
Discussion in '2.5 Gen Tundras (2014-2021)' started by Toney198, Oct 31, 2023.
  1. Oct 31, 2023 at 10:27 AM
    Toney198
    Toney198 [OP] New Member
    2014 1794 4X4
    I will start this with I am not even a shade tree mechanic, but youtube made it look easy and the dealership wanted an outrageous amount of money for it. So if any other non mechanics are on the fence, I changed oil in both diffs and the transfer case this weekend. The fill and drain hole plugs were torqued WAY above specs and I was scared of the amount of pressure it took to get them out, but they broke loose. Everything was straight forward but the transfer case oil was WAY thinner than the gear oil, so I bathed in that unexpectedly. Lucky I had a ton a cardboard down figuring I would do something like that.
    cmiles97, WILLINH, Gene_in_FL and 3 others like this.
  2. Oct 31, 2023 at 11:19 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Nice! If there was a previous owner, maybe they were the ones that over torqued it.
    I'm no mechanic either but anytime I can watch a youtube video and do something productive on the truck always makes me feel like a master mechanic when I'm done.
    I believe a lot of people on here have had a hard time with the front diff drain plug and possibly stripping. Did you have issues with that?
  3. Oct 31, 2023 at 11:26 AM
    Toney198
    2014 1794 4X4
    No the front wasnt as bad because the Hex fit tighter, The rear was 24mm and it just did not seem to fit as secure. I tried 2 deferent sockets, both had a little play.
    Jaypown likes this.
  4. Nov 6, 2023 at 4:13 PM
    Pr4sno
    Pr4sno New Member
    Loveland, CO
    What fluid did you put back into the T-case?
  5. Nov 6, 2023 at 5:36 PM
    Toney198
    2014 1794 4X4
    Ravenol from blaurparts. It was suggested MANY times over for one of the few “in spec” options. It appears very quality. To be honest, the way the quarts are set up with the special tube to fill, I wished I would have just bought the package deal they offer. Check them out if you are unfamiliar, they sell packages for all oil change options.
