Locating interior A/C fuse for 2021 TRD Pro
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ajramos05, Nov 5, 2023.
  1. Nov 5, 2023 at 1:05 PM
    Ajramos05
    Ajramos05 [OP] New Member
    My A/C control is blinking and I think I narrowed it down to my magnetic clutch relay but I want to check the A/C fuse. My interior fuse diagram does not indicate an individual A/C fuse.
    can someone tell me which is the shared fuse.
  2. Nov 5, 2023 at 1:32 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    On my 2015, there are several fuses that related to the A/C system:
    Under the Hood Fuse Box: #43 LH-JB A/C IG 150 amp fuse
    Under the Dash Fuse Box: #8 A/C 7.5 amp, #21 A/C IG 10 amp, and #24 Panel 7.5 Amp
  3. Nov 5, 2023 at 1:50 PM
    Ajramos05
    Thanks…it’s my understanding that the 2021 models are different but I cannot find documentation
  4. Nov 5, 2023 at 3:01 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Rare for the relay to fail.
    Does your gauge cluster show the outside temp or is it showing E?
  5. Nov 5, 2023 at 5:11 PM
    Ajramos05
    Yes, I can see the temp
  6. Nov 5, 2023 at 6:11 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
