Specs for the "motor generator" and non answer from Toyota
Discussion in '3rd Gen Tundras (2022+)' started by overl4nd, Nov 3, 2023.
  1. Nov 3, 2023 at 11:50 AM
    overl4nd
    overl4nd [OP] New Member
    I was planning a dual battery system on the hybrid, and wanted to know what are the AMPS specs on that (eg for alternator if its 180A then a 40A DC-DC is fine).
    Their non answer? Subscribe to techstream and search there.
  2. Nov 3, 2023 at 12:39 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    You really thought customer service getting paid minimal wage was going to give you a nerd answer not in the pamphlet?
  3. Nov 3, 2023 at 1:51 PM
    overl4nd
    Yes, but it was so easy with alternators to figure out the specs
  4. Nov 3, 2023 at 1:59 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    If your question is about the amp rating of the alternator on the Gen 3 Tundra, the answer is 180 amps.
  5. Nov 3, 2023 at 2:05 PM
    overl4nd
    The TRD Pro does not have an alternator. It has a "motor generator" . The Prius apparently can provide 100amps to 12V system(or fuse will pop) . No idea about the tundra motor generator. I guess I will have to go fuse locating :D
    tronz151 likes this.
  6. Nov 3, 2023 at 6:19 PM
    overl4nd
    I did ask the prius people and they have a 100A fuse and 40-40DC converters are used by them for dual battery systems. Do you know where our fuse is?
