Is it possible to connect to Network A and TPMS on ONDLink?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Black, Nov 2, 2023.
  1. Nov 2, 2023 at 5:20 PM
    Black
    Black [OP] Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Is it possible to connect to both networks so I can just swipe to my different dashboards.
    Currently, I have to disconnect from the vehicle and reconnect after choosing the network I want to use.
    Also OBDLink is reading about 15psi high for the tires.
    How do I go about calibrating it to read proper?
    If there is not a way to connect to both networks simultaneously is there a reader and display or app that will just provide me with TPMS info?
    I have a 2014 so TPMS readings are not available on the dash.
  2. Nov 2, 2023 at 7:48 PM
    JRS
    JRS New Member
    2012 DCLB
    I believe Network A is a request and response through OBD to CAN and not directly through CAN. For a 2014, TPMS is on LIN (K-line on the OBD plug), which is a completely different protocol. My assumption is that OBDLink isn't configured to have simultaneous comms because I've tried to do the same in the past.
