Which tools for front end bushing and LBJ replacement
Discussion in '1st Gen Tundras (2000-2006)' started by Fieldnstreamer, Nov 1, 2023.
  1. Nov 1, 2023 at 7:01 AM
    Fieldnstreamer
    Fieldnstreamer [OP] Cold Researcher
    Sam
    East Tn
    2006 DC Limited 4x4 Phantom Gray Pearl, 2000 AC Limited 4x4 (R.I.P.)
    Brute force bumpers/sliders, OME 3" lift, SCS ray 10 wheels, ARB onboard air compressor, GX460 big brake upgrade, JBA UCA's, siberian Bushings, RCV high clearance axles, 333 Billet steering rack clamp, TMR customs 10" front limit straps, 1" diff drop, agility customs dual battery setup/battery isolater with heavy duty wiring/ grounding cable upgrade, F-er battery tray, HFW spindle gussets, remote oil catch can,
    I've done almost every other job that can be done on these trucks but I've never replaced the lower control arm bushings or the lbjs. All my parts came in the mail yesterday so I'm wondering besides the basic shop tools I have, are there any special tools I need to rent from the parts store? What I've heard the most complaints out of are pressing the bushings out of the control arms. I have a pneumatic 20 ton press but I didn't know if there were any special dies that would make the job go faster. I have die grinders and almost every other tool but like I said I've never done this job so I don't really know what to expect but it's my daily so I can't have the truck torn down for more than a weekend.
    My upper control arms are jba uniballs so that's why I'm not replacing those bushings because they are new control arms. I started hearing a clunk in the front passenger side suspension area last week and I'm not sure what it is so I'm doing the bushings and lbjs and hopefully that fixes the random clunk.
  2. Nov 1, 2023 at 7:11 AM
    A sawzall and a handful of Diablo Demon carbide cutting blades for thick metal.
  3. Nov 1, 2023 at 2:21 PM
    GreenMachineDream
    GreenMachineDream New Member
    West Central, OH
    2002 Tundra SR5, 4WD, RCLB, Metallic Green
    If you're replacing the LCA bushings I know from experience it's easier to just replace the whole control arm. Buy the extra bolts and sleeves cause just as @Jack McCarthy said you'll want to cut those suckers off.
    Jack McCarthy likes this.
  4. Nov 1, 2023 at 2:33 PM
    Fieldnstreamer
    Sam
    East Tn
    What bolts and sleeves are you talking about? Like the alignment bolts?
  5. Nov 1, 2023 at 2:38 PM
    Yep. Sleeve freezes to the metal pass-through in the bushing. You can reuse the bolts, but not the alignment sleeves and the CAM nuts are debatable as to whether you want to reuse them or not. Depends if you can get them off cleanly.
    Easiest way to get those off are to undo the bolts about 1/2 to 3/4 of the way off and then hit the head with a mallet to pop the washer/nut off the backside.
  6. Nov 1, 2023 at 2:58 PM
    Fieldnstreamer
    Sam
    East Tn
    What's the consensus on those cam nuts that are four position and are for more off-road use that are apparently a little bit more reliable to keep in alignment? I've thought about those but I don't know how reliable they are to keep your vehicle aligned without messing up your tires.
  7. Nov 1, 2023 at 3:01 PM
    The only other ones I’m aware of are the SPC ones and those are partially plastic from what I read here.
    I’d just get the OEM CAM sleeves and the CAM washer/nut to have on hand and once you get it apart you can decide what to keep and what to return if you want to save money. Most places give you 2 weeks to return.
    The bolts you can easily clean up and reuse.
    noahrexion likes this.
  8. Nov 1, 2023 at 5:34 PM
    Fieldnstreamer
    Sam
    East Tn
    The solo motorsports are the ones I was referring to. To me a little bit to remember who the manufacturer was. https://solomotorsports.com/shop/pa...a-parts/toyota-alignment-cam-tab-upgrade-kit/
  9. Nov 1, 2023 at 5:41 PM
  10. Nov 2, 2023 at 5:17 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Those look pretty trick to me - I like em. I can't see any issue (quality) wise at all.
    Please document what you end up doing - may follow behind shortly with my whip now that winter is settling in.
