Passenger side door handle
Discussion in '2nd Gen Tundras (2007-2013)' started by Markcjr, Nov 1, 2023.
  1. Nov 1, 2023 at 6:32 AM
    Markcjr
    Markcjr [OP] New Member
    2010 Toyota Tundra SR5 Double Cab 5.7 FFV 4X4
    I have a 2010 Tundra and have a problem with the front passenger side door when opening it. When ever I pull the exterior handle, it opens like normal but the door will stop while slightly ajar and I have to pull the handle again to unlatch it and open the door all the way. This only happens from the outside; the interior handle opens perfectly fine. Because it only happens when opening outside, I assume it’s probably the exterior door handle that needs replaced. I wanted to get some advice before ordering a new handle.
