How best to fix and prevent intercooler damage?
Discussion in '3rd Gen Tundras (2022+)' started by fastarget, Apr 9, 2023.
  1. Apr 9, 2023 at 7:02 PM
    fastarget
    fastarget [OP] New Member
    Started a discussion back about the need for some screens for bugs to protect all these coolers, what I did not expect is a small hail storm here in the rockies while on the highway, pea size hail or smaller.
    Regardless, here is what happened to the intercoolers.
    How do I repair this, radiator combs dont work here, and what about preventing ?
    =JSG= and Paul Moll like this.
  2. Apr 9, 2023 at 8:22 PM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    Sure seems like there is a business opportunity for someone to come up with a metal mesh, thinking "hardware cloth" that is custom fit over the intercooler and radiator of our gen 3 tundras. Any takers??
    woods likes this.
  3. Apr 9, 2023 at 8:55 PM
    fastarget
    Used to place a hard stainless mesh ahead of coolers on race cars. Thinking of some way to frame and fit the cut out, something easy to install.
    mayan likes this.
  4. Apr 10, 2023 at 9:20 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    I put window screen on the backside of my grille to keep all the bugs out of the radiator and intercooler and it works great. It's flexible and soft so it won't chafe on anything.
    Mattedfred likes this.
  5. Apr 10, 2023 at 9:31 AM
    Paul Moll
    Paul
    Idaho
    Interesting. Got pictures?
  6. Apr 10, 2023 at 10:11 AM
    Tb2
    Tb2 New Member
    James
    I can tell you from experience the cooler up front as in tundra is not so much a bug issue as a rock hitting radiator of turbo and knocking a hole in it. you warranty doesn't cover this .
    I have a Porsche 911 that got hit in AC coolers up front leaked out all freon , warranty would not cover insurance claim did plus deductible .This has been a common problem on 911's and several manufacturers make a mesh screen that doesn't restrict air flow and is heavy enough to keep rocks from busting the cooler .
    some require bumper removal and some don't for installation .
    I hope someone comes up with an aftermarket fix.
    It will happen sooner or later .
  7. Apr 10, 2023 at 10:26 AM
    Retired...finally
  8. Apr 11, 2023 at 8:22 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    I put it in mainly to keep bugs and debris out of the radiator and intercoolers. It may slow down a rock but not stop it.
    Tundrastruck91, woods and pwpblue like this.
  9. Apr 11, 2023 at 10:20 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    Could be my crappy picture as well, it's soft screen. Makes getting it in without taking apart the whole front end much easier.
    Tundrastruck91 and Mattedfred like this.
  10. Apr 11, 2023 at 10:28 AM
    aj350925
    aj350925 New Member
    Yea, I do the same on my race cars.
  11. Apr 11, 2023 at 1:09 PM
    Paul Moll
    Paul
    Idaho
    Looks good, and I agree that it probably does little for rocks. Maybe smaller "stones" are stopped or slowed down enough. But looks easy and cheap to install.
  12. Apr 11, 2023 at 8:42 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    How about the possibility that adding a mesh would restrict air flow?
    Supposedly, the air intake and radiator that we have has exact air flow that's needed to cook these turbos etc.
    How do we go about doing this safely?
  13. Apr 11, 2023 at 10:23 PM
    Tom976
    Tom976 New Member
    Tom
    The material used looks like what i had used long ago with an 06 Honda Odyssey.
    Went down to Home Depot and picked up a roll of black pastic gutter guard. Basically its a roll of plastic mesh about 6 inches wide x 20'.
    Doesnt keep out the super small stuff but slowed down or stopped the larger stuff.
    HD show this stuff locally for the high cost of 93¢
  14. Apr 12, 2023 at 11:41 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    Works great, it's easy to pull out but the bugs dry out and fall off so not much need to remove it as of yet.
    Mattedfred[QUOTED] likes this.
  15. Apr 12, 2023 at 11:43 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    I drove it across country last summer pulling our toy hauler over the Rockies and Cascade mountains with temps in triple digits and experienced no over heating issues. I've done this for years on all of our cars and I've never had any issues with any of them. I imagine if it plugged up with a lot of bugs it could be an issue but when the bugs dry out they just fall off.
    woods, Kap1[QUOTED] and Mattedfred like this.
  16. Apr 13, 2023 at 8:48 AM
    fastarget
  17. Apr 15, 2023 at 6:55 PM
    fastarget
    ok not to sound the alarm, tried a small screwdriver to try and improve my situation, the fins are paper thin and softer than paper, no effort required to bend stuff, hard to straighten because they are so soft they fold. I am not exaggerating, I think they will get damaged with bug strikes easily. I dont understand how a cooler in such an exposed spot is this fragile.
  18. Apr 15, 2023 at 9:16 PM
    Retired...finally
    Wait until you get a few N/E winters worth of salt on the thin aluminum.
  19. Oct 27, 2023 at 10:24 AM
    Chomponthis
    Chomponthis New Member
    Billings, MT
    2023 Tundra Limited Cremax 4x4, TRD OR
    Has anyone installed something a bit more rigid?
    Modengzhe 40 x 13 inch Car Grill Mesh Sheet, Black Painted Aluminum Alloy Multifunctional Grille Mesh Roll, 3 x 6 mm Rhombic-Shape Grids https://a.co/d/hPvYDFo
    Onetrack97 and AND like this.
  20. Oct 30, 2023 at 2:12 PM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    how exactly did you “instal” the screen? Friction fit? Zip tie?
  21. Oct 30, 2023 at 3:19 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Just drive backwards? :hattip:
    Saltyhero13, 75tranzam, woods and 2 others like this.
  22. Nov 6, 2023 at 9:35 PM
    Oldandfat
    Cannuckastan
    is it hardware cloth? 1/4”? Zip tied?
  23. Nov 11, 2023 at 1:41 PM
    LouALouA
    LouALouA New Member
    Lou
    Central Florida
    2023 1794 Blueprint 4x4
    This is what I used on my 911 Turbo S. From Zunsport.com in England. They make one for Hilux. (AKA Tacoma. I think) Since a Tundra wouldn't fit on most Euro roads, they probably won't make one. But if enough folks ask then maybe?
    woods likes this.
  24. Nov 17, 2023 at 6:49 AM
    Chomponthis
    Billings, MT
    I went ahead purchased some grill mesh on Amazon.
    I initially installed the mesh onto the grill and thought it looked TERRIBLE so I removed it.
    Then I went ahead and installed the mesh directly onto the coolers, removing the ducting helped get a good fit.
    Jettster and AND like this.
  25. Nov 17, 2023 at 9:14 AM
    Tom976
    Tom976 New Member
    Tom
    Which material did you buy and how much did you actually need to cover the turbos?
  26. Nov 17, 2023 at 1:55 PM
    Chomponthis
    Billings, MT
    I used this material: https://www.amazon.com/dp/B0BD7KSRWM?ref=ppx_yo2ov_dt_b_product_details&th=1
    I bought the largest sheet, but the cutouts were exactly 12 1/2" X 11 1/2" so you can get the smaller sheet.
    If you want additional information on how to get the ducting loose let me know.
    Blufin, Kap1 and TundraDan723 like this.
  27. Jul 23, 2024 at 6:11 AM
    2024 Tundra
    2024 Tundra Excuses are easy to manufacture, but hard to sell!
    2024 Tundra Hybrid
    Undercoated, Banks Gage, mud flaps, Derale transmission cooler
    It looks like you have to remove the front grill to install the screen? Any disassembly help would be appreciated. Also in post #24 the 2nd photo it looks like the screen has a crimped edge to it? Thanks in advance.
  28. Jul 23, 2024 at 6:16 AM
    Chomponthis
    Billings, MT
    I didn't have to remove the grill, I did have to remove the bolts to the ducting so I could slide the mesh protection.
    I didn't crimp any of the edges.
  29. Jul 23, 2024 at 7:32 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Well seeing how this thread was resurrected from the dead...can you still share how you got the ducting loose?
  30. Jul 23, 2024 at 8:33 AM
    Chomponthis
    Billings, MT
    I think there are 3 or 4 bolts holding the ducting in i just removed the bolts and that gave me enough clearance to insert the mesh sheet.
    TundraDan723 and AND like this.
