KO2 Issue, what are your thoughts?
Discussion in 'Wheels & Tires' started by FirstGenTundra, Oct 30, 2023.
  1. Oct 30, 2023 at 2:17 PM
    FirstGenTundra
    FirstGenTundra [OP] R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I've had these tires on my truck since Oct. of 2019. They have been an outstanding tire to date and have served me very well through four Wyoming winters. I will replace them with another set of KO2's when the time comes (which I think is now). I was adding air to my tires the other evening and noticed I have what appears to be a tear in the carcass and some other cracking in the beefed up sidewall lugs. Has anyone seen this before? Is it dry-rot? I don't believe I hit anything that would have cut into the tire like this but it's not impossible.
    ADCreHeBpuMK3KbrbIYPcOnDd_8m6vvk1DjlnaCK_4e36c4b1c9b0107bb9f400965337c58a249306ed.jpg
    ADCreHeIgbdU9JXPfyOrUMfvcqaBAynLtfkPWLAf_f5227a0452664928fdf7f777ac7eb262eca6a8bc.jpg
    ADCreHdJUADKZZNdd35lUeD90MEiPjJKCoREY6cL_54f6d6711687479ac1e69ffc53559d96fc9e1bcf.jpg
  2. Oct 30, 2023 at 2:50 PM
    AZBoatHauler
    So.Arizona
    Looks like it got cut. I’ve never seen tires 4 years old that didn’t have cracking but I live in the desert so :notsure:
    FirstGenTundra[OP] likes this.
  3. Oct 30, 2023 at 2:56 PM
    AZBoatHauler
    So.Arizona
    2.5 year old Nitto RGs.
  4. Oct 30, 2023 at 3:01 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Time to replace. I have KO's on my 2015 and still going strong.
  5. Oct 30, 2023 at 3:01 PM
    blenton
    blenton New Member
    I would also venture a guess that it is a tear, mostly likely from a rocky trail or dirt road. I had a similar tear on my coopers that was up higher on the tread but very close to the sidewall meat and definitely came from a rocky road. I've also seen similar tears from the shale rock that sometimes line's the road shoulders on forrest service roads.
  6. Oct 30, 2023 at 3:10 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I have a few similar cuts on my Volvo's KO2. A few travels up north in remote parts of Canada, they took quite a bit of beating. I still think they are bulletproof, because they survived cracked wheels.
    However my Tundra is on General Grabber A/TX now. I think they are a bit quieter and more potent in winter.
  7. Oct 30, 2023 at 3:13 PM
    I had something similar on the 4R with Ko2, and kept driving them for another 30k until the dry rot set in on other tires and started leaking
  8. Oct 30, 2023 at 3:53 PM
    FirstGenTundra
    Daniel
    Wyoming
    I'm debating whether or not to replace them. I'd hate to have a blow out and wreck my truck because I didn't want to spend $1300. The tread is down to 6 or 7/32nds depending on where you measure. I was planning to replace them sometime next year.
  9. Oct 30, 2023 at 3:55 PM
    FirstGenTundra
    Daniel
    Wyoming
    I was out hunting a week ago and on some pretty rough BLM roads. I was trying to be careful but it is likely what happened.
  10. Oct 30, 2023 at 4:15 PM
    highhrider
    highhrider New Member
    Brentwood, CA
    2023 Platinum HV 6.5
    I’ve had my KO2’s since 2015 with 30k miles and no cracks really. Very very small hair line ones. Tread is now 7.5/32.
    @FirstGenTundra , maybe see if bfgoodrich will cover them under warranty if you haven’t hit anything?
  11. Oct 30, 2023 at 4:16 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I have thus far found the wildpeaks to be all around better than the K02’s. however, I have not yet driven them in the snow.
  12. Oct 30, 2023 at 5:46 PM
    blenton
    blenton New Member
    Hopefully not playing checkers in Carbon County...
  13. Oct 31, 2023 at 5:52 AM
    FirstGenTundra
    Daniel
    Wyoming
    Lol, ain't that the truth. No, I was up in Johnson County.
  14. Oct 31, 2023 at 5:57 AM
    FirstGenTundra
    Daniel
    Wyoming
    Wildpeaks are the only other tire I'd even consider putting on my truck. I'm afraid to stray from what I already know though when new tires are approaching $1400 mounted and balanced. I do believe they are a solid choice.
    ZappBrannigan[QUOTED] likes this.
