HVAC display/fan
Discussion in '3rd Gen Tundras (2022+)' started by Northern Toyota, Oct 29, 2023.
  1. Oct 29, 2023 at 7:27 AM
    Northern Toyota
    Northern Toyota [OP] New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Question for fellow 3rd Gen owners;
    When on the auto climate setting, does your screen show you fan speed? Or where the air is coming from? My 2020 tundra and current 22 Tacoma will show you both of these when on auto. Also if I switch from auto to any other setting, say vents for example, it still doesn’t show my my fan speed until I change the fan speed by pressing the toggle button.
    Not sure if this is a glitch on my tundra or someone in their infinite wisdom at Toyota thought this was a good idea?
  2. Oct 29, 2023 at 8:40 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Mine is exactly the same
  3. Oct 29, 2023 at 9:24 AM
    Northern Toyota
    Tires and bilstein
    Thanks guys. After being accustomed to the old style Toyota display I found this a little annoying. At least I know it’s not a software glitch
    pwpblue likes this.
  4. Oct 29, 2023 at 9:26 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Sure. If you can figure out how to turn off the AC compressor and have only the outside air blowing, please let me know... Even though I click on the AC button and it says AC Off, I can still tell ac is working and blowing cold air
  5. Oct 29, 2023 at 10:36 AM
    Northern Toyota
    Tires and bilstein
    When I bought my truck, September 25 of this year, I definitely didn’t need ac here in the north east. My display didn’t show ac on or off. I noticed the ac drain tube dripping in my garage, so next trip I pushed the button then “ac off” displayed. Ever since then it’ll either say ac on or ac off. I think if you use defrost mode (the separate button) it defaults to ac on to put dry air on the windshield to clear the fog. In previous vehicles I’ve owned this setting would automatically turn on the AC light. My tundra doesn’t show AC on but I know it is.
    under the auto climate control settings in rhe head unit you can turn auto AC off, which I’ve done in my previous Toyota’s and for the most part I believe it’s off.
    Kap1[QUOTED] likes this.
  6. Oct 29, 2023 at 11:12 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Try turning the AC off, turn the recirculating air off, then turn the temp setting to LO. You should get outside air.
    pwpblue and Kap1[QUOTED] like this.
