Four wheel drive not working
Discussion in '2nd Gen Tundras (2007-2013)' started by mike11895, Oct 28, 2023.
  1. Oct 28, 2023 at 5:33 AM
    mike11895
    mike11895 [OP] New Member
    2010 tundra doublecab long bed
    I have a 2010 tundra and the four wheel drive does not work. Any solutions to try?
  2. Oct 28, 2023 at 7:35 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    When you select 4wd what happens? Are you getting any indicator lights?
  3. Oct 28, 2023 at 9:55 AM
    mike11895
    Yes the lights come on and are solid as if it were engaged
  4. Oct 28, 2023 at 5:38 PM
    huntertn
    huntertn New Member
    Tennessee
    If the 4hi light is solid then the transfer case and front differential should be engaged.
    Did it work at one time but now it doesn’t?
    This is really stupid to say but I would make sure that the front driveshaft is installed.
    What makes you say it’s not engaged? No power to the front wheels?
  5. Oct 28, 2023 at 6:04 PM
    mike11895
    Maybe it never did work. No power to front wheels
