Dying battery on HV
Discussion in '3rd Gen Tundras (2022+)' started by PlatinumArt22, Oct 28, 2023.
  1. Oct 28, 2023 at 7:05 AM
    PlatinumArt22
    PlatinumArt22 [OP] New Member
    Art
    '22 Tundra Platinum Hybrid
    Having a problem starting my 22 Platinum. It is almost like there is a draw on the battery. I had to do some traveling and left it at home. Eight days into my trip, I tried remote starting and found out it had a dead battery and wouldn't start. When I got back, I called R.A. for a jump. Got it started, ran it for a bit, drove it for another bit, got the battery charged back up. Turned it off, waited a few minutes, and started it again. No problem. Next morning, it started just fine. Then yesterday morning, hopped in and it was dead again. I am suspecting that they dash cam is creating a draw on the system. Damn thing doesn't work right anyway. I think it just stays on continuously. DashCamProtect. I unplugged it last night and it remote started this morning.
    Anyone else experience a problem like this?
  2. Oct 28, 2023 at 7:23 AM
    Breathing Borla
    Northern Illinois
    Go have the starting battery load tested , it’s not un heard of to have a bad battery
    PlatinumArt22[OP] likes this.
  3. Oct 28, 2023 at 8:33 AM
    Tom976
    Tom976 New Member
    Tom
    Do a battery load test with a meter and go from there.
  4. Oct 28, 2023 at 9:06 AM
    FLKX
    FLKX New Member
    Rewire your dashcam so it's switched.
    PlatinumArt22[OP] and ryanwgregg like this.
  5. Oct 28, 2023 at 9:35 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    It's easy to test for a parasitic drain (or short) on the battery. Just disconnect the negative battery cable, then connect an automotive test light to the cable and touch the probe to the negative battery post. If the light comes on, there's a drain. If so, you can pull fuses one by one until the light goes out. That will be the circuit that the drain is on.
  6. Oct 30, 2023 at 9:31 PM
    pnw.tundra
    pnw.tundra PNW Tundra
    Paul
    PDX
    2022 TRD Pro | Prev 2020 Tundra aka Blue Whale
    My 22 Pro (hybrid) had a battery failure found during my 25k service. They replaced it under warranty, so I suggest you take your truck in for diagnostics.
    PlatinumArt22[OP] and 1lowlife like this.
  7. Oct 31, 2023 at 4:48 AM
    PlatinumArt22
    Art
    Was this the 12V or the Hybrid battery? I plan on taking it in, but I did narrow it down to the dealer installed dash cam. I unplugged it and am waiting for dealer to fix it. The dash cam manufacturer is actually dealing with it.
  8. Oct 31, 2023 at 5:01 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Of course the light will come on. This is not the 1970s vehicle where a 12 Volts relay was the most advanced piece of electronics. This truck has like 50+ computers. Once the battery is connected, there will be a significant "drain" until all the computers go low power.
  9. Oct 31, 2023 at 6:07 AM
    pnw.tundra
    Paul
    PDX
    It was the 12v battery. They replaced it with a true start.
