JBL Amp bypass
Discussion in '1st Gen Tundras (2000-2006)' started by Shane81, Oct 28, 2023.
  1. Oct 28, 2023 at 6:46 AM
    Shane81
    Shane81 [OP] New Member
    2005 tundra double cab SR5
  2. Oct 28, 2023 at 7:15 AM
    shifty` Animals and insects don't do drugs
    Loose wire and/or fried channel.
    How did you make your connections? Wire nuts? Butt splice or similar crimp? Solder and heatshrink? Twist and electrical tape?
    Only two of the four I just listed are acceptable, the other two are skimp-ass, rigged garbage that any reasonable human should be ashamed to use.
    One of the two acceptable methods in that list needs to have tug-test done after to ensure solid connection.
