Fleabay Flip to key to flip key swap, Super easy
Discussion in '2nd Gen Tundras (2007-2013)' started by KeepOnTruckin, Oct 27, 2023.
  1. Oct 27, 2023 at 3:58 PM
    KeepOnTruckin
    KeepOnTruckin [OP] New Member
    Randy
    2010 4.6 4x4 Bare Bones
    About a year ago, I bought cheap flip key from fleabay.
    The good - our OEM door remote PCBA drops into fleabay flip key. Obviously the key needs cut and registered. The bad: it's cheap and it broke.
    Fast forward to new key arrival an hour ago that replaces broken flip key which won't stay open or flip open and it's fugly.
    So, I bought the delux $21 model which feels solid but it has trunk button. It needs a Yoda emblem and all would be well.
    Here is the fun part, if you push out the roll pin, the keys blade swaps to the newer body, push in the roll pin and you're set. While the remote is open, snag the G-code chip for the ignition and walla, most of the work is done! No ignition key cutting or registration! Reassemble the body and program the door remote. This feels like a solid remote assembly compared to the other.
    I tried using the Yoda key in/key out, door open/door closed trick to register the remote but the truck wanted nothing to do with that. So I fired up Techstream and registered the door remote.
    Bad news though, I bought two of these and only one would talk to the truck. Techstream diagnostics sees output from the bum remote but it won't register it.
    I don't honestly need it, so I didn't spend much time after that. Truck shows 3 of 4 keys registered, the light on the remote works for both buttons... Didn't check battery health (came installed already)...
    So, for $21 we are up and running again.
    If I recall, it cost me $70'ish to register last key. From now on, I'll pay for cutting if need be.
    PhotoNerd likes this.
  2. Jul 13, 2025 at 7:17 AM
    gotanickle
    gotanickle New Member
    2008 tundra Crewmax
    I am interested in doing this, do you have the manufacture or a link to where you got the new key fob from. Thanks.
  3. Aug 4, 2025 at 3:29 PM
    19_Sr5_XSP
    19_Sr5_XSP New Member
    2019 Sr5 XSP
    None for now
    question on this
    did you take your OEM internals from your original key & put them into the new Deux/4 button key?
    or did you not need to do that & that you only HAD to swap in the transponder from the old key ?
    seems like you actually transferred over the original key blade as well instead of having the duex blade cut (was it cut able? or wrong style?)
    im looking at this one at the moment which looks like yours, but want to know what Im getting into...I assume that this key WILL NOT take the oem keys electronics (buttons) & uses its own & needs to be programmed ? (or trained/learned via a door open /close etc process?)
    Then I would cut my transponder out of my OEM key & place it in here & then have the blade cut
    https://www.amazon.com/Keymall-Replacement-Upgraded-HYQ12BBX-HYQ12BAN/dp/B089VSQVXK/
