Popping noise after installing coilovers
Discussion in 'Suspension' started by Jebber3, Oct 23, 2023.
  1. Oct 23, 2023 at 4:31 PM
    Jebber3
    Jebber3 [OP] New Member
    2018 Tundra TRD Off Road
    Silly question… I’ve got a 2018 TRD Off-road and recently had 2019 Fox Trd pro coilovers installed with a 1/4” shim for a total of 2.5” lift up front. Based on what I’ve read, less than 3” should clear the upper control arms without issue. The first time I drove it I noticed a pop when turning. It’s particularly noticeable when backing out of a parking space and cranking the wheel. I mentioned it to the guy at the alignment shop who said to bring it back in a week if it’s still making the noise. Doesn’t make sense to me that the sound would just go away.
  2. Oct 23, 2023 at 5:47 PM
    What wheel and tire setup do you have?
  3. Oct 23, 2023 at 6:52 PM
    Jebber3
    Factory wheels with 275/65/18s.
  4. Oct 24, 2023 at 5:53 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    Check your sway bar links. They pop like that when not all the way tight
    equin likes this.
  5. Oct 25, 2023 at 8:39 AM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    Also if you have cat guards and a TRD Pro skid plate. They are noisy as hell where they meet up. I get the popping noise at slow speeds for instance when going through a tight drive through. I was told by a Toyota tech to use rubber grommets between the plates. I have everything, just need to do it.
    Jebber3[QUOTED][OP] likes this.
  6. Oct 26, 2023 at 1:15 PM
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    Having a similar issue slow speeds or hard right turns at slow speeds only or speed bumps sometimes. Toytec 2.5 alumas truck on has 53k on it. Also jba ucas and trd pro sway bar. I can’t see it being tie rods or lower ball joint.
  7. Oct 26, 2023 at 3:24 PM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    Maybe try torquing the lower control arms, I found that worked for me :cheers:
  8. Oct 26, 2023 at 3:44 PM
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    Yea I was gunna do that but could get the angle right with my torque wrench without pullling tires and ehhh I’m too lazy right neck
  9. Oct 26, 2023 at 4:28 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    If the lower strut bolt was not tightened with the vehicle weight down on the tires on the ground, or at least jacking up the lower control arm if the truck was still on Jack stands to its natural position before torquing it down that can cause a popping sound I’ve read.
    AggiePhil, Lemuel1 and equin like this.
