U-bolt plate orientation
Discussion in 'Suspension' started by Nbab23, Oct 14, 2023.
  1. Oct 14, 2023 at 9:42 AM
    Nbab23
    Nbab23 [OP] 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Added the extra leaf to my icons and right as I was going to start putting the u-bolts back on the rains came. I grabbed the plates and bolts and put them in my garage. When I came out this morning I realized, having done this before, I never looked at how the plates were oriented and just always laid them flat on the ground in the correct orientation. Obviously there is a slight angle to the plate, just wasn’t sure which way the angle went. This is my drivers side. I think it goes on just like this. It doesnt feel quite right the other way but was wondering others thoughts?
  2. Oct 14, 2023 at 9:52 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Installed looks to have more overhang towards the back.
  3. Oct 14, 2023 at 10:12 AM
    biebs96
    PA
    Just crawled under mine. Looks similar to how yours is.
    Nbab23[OP] likes this.
  4. Oct 14, 2023 at 10:13 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Awesome thanks for checking.
    biebs96[QUOTED] likes this.
  5. Oct 14, 2023 at 10:16 AM
    biebs96
    PA
    no problem. That’s how we roll here.
    Nbab23[QUOTED][OP] likes this.
  6. Oct 26, 2023 at 11:32 AM
    king.cong.1119
    king.cong.1119 New Member
    I had the same question when I replaced my leaf last week, after inspecting, I believe it doesn't matter which way you put it, that angle is going to stay the same for each side. Try turning it 180 and the notch still faces the same way, however, there is a difference between left and right plates.
  7. Oct 26, 2023 at 11:48 AM
    coTony
    Tony
    Montrose, CO
    If you lay under your truck at the rear looking towards the front you will see the angle of the leafs and they are not parallel with the frame.
    When you see that angle you will see your answer grasshopper :notsure:
  8. Oct 26, 2023 at 12:22 PM
    coTony
    Tony
    Montrose, CO
    Ok, I tried laying down like I said and it is not that obvious. When it is up on a rack it is. I may have a pic somewhere...
  9. Oct 26, 2023 at 12:27 PM
    king.cong.1119
    Something like this
    AggiePhil and coTony[QUOTED] like this.
  10. Oct 26, 2023 at 12:28 PM
    coTony
    Tony
    Montrose, CO
    You can see how the frame is EDIT: Wider in the front that the rear the way it curves. Not the best image but if you zoom in you can see where the front shackle is relative to the rear shackle
    Coachbuilder1 likes this.
  11. Oct 26, 2023 at 12:32 PM
    coTony
    Tony
    Montrose, CO
    I believe it is the opposite, wider in the rear. I did not do this but measure shackle to shackle, front to front and rear to rear
  12. Oct 26, 2023 at 12:34 PM
    king.cong.1119
    I am 90% sure its wider in the middle and narrower in the rear and front.
    coTony[QUOTED] likes this.
  13. Oct 26, 2023 at 12:39 PM
    coTony
    Tony
    Montrose, CO
    NICE PIC!
    No wonder you have problems getting a 35" tire under there. Problem solved!
