power lost
Discussion in '2nd Gen Tundras (2007-2013)' started by Pelon249, Oct 24, 2023.
  1. Oct 24, 2023 at 9:02 PM
    Pelon249
    Pelon249 [OP] New Member
    2014 Tundra 1794 edition
    none
    Door locks, interior and Exterior Lights lose power after I turn the ignition key off. Any clue what might be causing this?
  2. Oct 26, 2023 at 6:18 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Normal? if you're opening the door, once you remove the key, I do believe you get like 10-30 seconds of power to close your windows, but once the driver door is open, maybe any door that's open it cuts the power. Not sure about the headlights, those usually turn off once the alarm is set. Your case may be slightly different since you probably have a 2014.
