Eaton e-locker leak
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sonicbluerider, Oct 15, 2023.
  1. Oct 15, 2023 at 5:10 AM
    Sonicbluerider
    Sonicbluerider [OP] New Member
    Dennis
    2019 Tundra
    Ya I'll go shop tomorrow, however I would like to know what would have started my problem an solution . My rear end is leaking fluid where the electrical wire enters the rear end housing for my eaton e-locker. Just started, I used it several times while in Wyoming an when we got back , clean trucks bottom an zero oil/ grease showing at that time .I've only driven truck 50 miles,at most,since then . Any ideas . Is that plug just a simple screw in. An held in with rubber o-rings??
  2. Oct 15, 2023 at 6:39 AM
    CaptRatBoy
    CaptRatBoy New Member
    Somewhere around 2500' Western Blue Ridge, NC
    Capeable, extensively modified, 2016, Limited, 4 x4 Tundra Off Road, 3td. one
    If it's leaking at the drilled grommet hole, mine seeped occasionally, try cleaning the crap out of it and I mean get it really clean, then get some 3M 5200 marine sealant and apply a thin bead around the grommet. If the grommet is toast order and replace. Also you can try "venting" the axle assembly that cured mine completely on our first Tundra build.
  3. Oct 15, 2023 at 6:54 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    Thanks ,ya mines vented to taillight housing for when an yes water crossing!
  4. Oct 15, 2023 at 7:44 AM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    I’ve had mine installed for a couple years, as soon as I got home from the install I put a bead of silicone around it for piece of mind and it hasn’t leaked at all
  5. Oct 15, 2023 at 8:09 AM
    Sonicbluerider
    Dennis
    2019 Tundra
  6. Oct 15, 2023 at 4:03 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    Ya silicone was shot thanks
    ZappBrannigan likes this.
  7. Oct 26, 2023 at 5:57 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    In Shop no problem with wiring . yaaaa. They lengthen wire connections an reclauked ..
    HulkSmurf14 and des2mtn like this.
