Do These #'s Still Hold True For 14plus>>>
Discussion in '2.5 Gen Tundras (2014-2021)' started by 737fixer, Oct 26, 2023.
  1. Oct 26, 2023 at 3:58 AM
    737fixer
    737fixer [OP] New Member
    Found this while looking for numbers on brake pad OEM original thickness compared to when dealers tell you when they need to be swapped. Yes, I only do this work myself but still curious of original thickness as opposed to when dealers tell customers to change their pads when 6mm are left. Just looking for an updated version of this chart or is this one still spot on. Thanks all as usual.brake.jpg
  2. Oct 26, 2023 at 4:12 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yes. Though I started getting occasional wear indicator squeaks with about 2-3 mm left in the front. Upon removal the metal lip was level with the remaining pad lining.
