Used Tundra drive light?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraAmazon, Oct 25, 2023.
  1. Oct 25, 2023 at 2:56 PM
    TundraAmazon
    TundraAmazon [OP] New Member
    2017 Toyota Tundra
    Hi! I bought a 2017 Tundra. It was pretty nasty. I just undid a couple screws and noticed that there’s a led but maybe whatever poured on it shorted it out.
    What is the part I’m looking for? I have a pic but can’t find it. Also, there’s two little cables that go in to the bottom of it but I don’t know how to connect it since if I push down with a new one the cables will slide down.
    What bulb/led am I looking for and what do I do to get those two cables to snap in if I find a new light?
    thanks a million!
  2. Oct 25, 2023 at 3:47 PM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    35959-0C010 : LED, Position Indicator ~$13
    35906-0C020 : Wire Sub-Assembly, Indicator Lamp ~$15
    The little led board lights up the shifter letters next to the shift knob. You should be able to pull the wire up in order to plug into the led board, and then button it all back up. Fwiw I started with the "75G221-011?" printed in the top left corner in your pic, that gave the general part number for the shifter, and pulled up the parts diagram using the Toyota parts store for my local dealership (parts.nameofyourdealership.com)
    You might try replacing just the led first, and if that doesn't work, replace the wire and keep working backwards. Good luck with the cleaning and congrats on the new truck. I recently bought mine as well and love it.
