Looking for pics
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by DanRob, Oct 25, 2023.
  1. Oct 25, 2023 at 10:55 AM
    DanRob
    DanRob [OP] 2.5 GEN. TUNDRA
    Chesapeake, VA.
    Id like to get an idea on what my Tundra will look like.
    3"front 2"rear leveling kit
    285/75/18 Nitto Recon (stock rims)
  2. Oct 25, 2023 at 12:21 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'm confused... a 3/2 leveling kit on top of a 'Pro' suspension is really not a 'thing'; the Pro suspension is already 'level'.
    Or are you in a non-'Pro' Tundra? If so, this would make more sense, and you'd get a better response posting in the general Gen 2.5 threads instead of the 'Pro' threads.
    DanRob[OP] likes this.
  3. Oct 25, 2023 at 12:25 PM
    DanRob
    Chesapeake, VA.
    yeah its not a Pro Tundra, I'm new at using this thing.
    Tripleconpanna likes this.
  4. Oct 25, 2023 at 12:45 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    This is close, 285/75 tires, stock wheels, 2 inch lift in front and 1 inch lift rear. No rubs, still have mudflaps and no messing with inner fender. Did trim the skid just in case.
    If I had wider rims, wheel spacers or different offset, Id have to lose the mudflaps and maybe push the inner fender. My brand of tires have thinner tread area vs wildpeaks and some others so tire brands that run wider will need more tweaking, just like lower offset wheels. Tires are 34.8 tall.
  5. Oct 27, 2023 at 2:54 PM
    Ginsterkev
    Ginsterkev Lessons not learned in blood are soon forgotten
    Kevin
    Pennsylvania
    2019 tundra Trd pro supercharged
    Tvs1900 magnuson blower Team rxp catch can Wescott designs collar lift on fox factory suspension Front and rear TRD sway bars
    295-70-18 nitto ridge graps and Westcott lift with the factory pro suspension, so extra 1.7 up front and 1.0 inch rear, removed little flappy thing in front of front wheel, no wheel spacers
    Crady, TUNDRA375, DanRob[OP] and 2 others like this.
