Which coil spring do I need for bilstein 4600?
Discussion in 'Suspension' started by Sengx1, Oct 5, 2023.
  1. Oct 5, 2023 at 8:12 PM
    Sengx1
    Sengx1 [OP] New Member
    Seng
    2007 tundra SR5
    Level 8 wheel tracker 1/2" leveling kit Hankook dyna pro at2s
    My 2007 tundra's OEM coil spring is cracked and therefore cannot be reused on new set of bilstein 4600. I am having quite the difficulty finding new OEM springs or replacement springs that'll be similar to stock.
    I read something about spring rate for new springs but I have no idea what to get..
    Truck is a 2007 4.7 V8 with TRD Offroad package. It has a front custom skid plate and metal grill guard if that means I should goto a higher spring rate? Also it has a 1/2" leveling kit.
  2. Oct 5, 2023 at 8:53 PM
    Get rid of the leveling kit and get some OME or Eibach springs for your 4600s.
  3. Oct 6, 2023 at 2:54 AM
    Sengx1
    Seng
    2007 tundra SR5
    Would the springs not support the leveling kit? Im still a noobie at all this suspension stuff. It came with the leveling kit and I like the ride height with it
  4. Oct 6, 2023 at 3:49 AM
    The new springs would be what lifted the front ride height. Wouldn’t need the level kit anymore.
  5. Oct 6, 2023 at 4:41 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
  6. Oct 6, 2023 at 6:41 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Find a set on craigslist or offer up
  7. Oct 6, 2023 at 7:13 AM
    Sengx1
    Seng
    2007 tundra SR5
    Thanks Trident! Exactly what I needed.
    And Knabores, I'm not opposed to getting the entire Eibach shock and spring kit. Never heard of Eibach before, is it a good brand?
    The 4600 is meant for stock height only I believe and lacks lift adjustability.
  8. Oct 24, 2023 at 9:05 PM
    SARR06TRD
    SARR06TRD New Member
    Sparksparts.com does not have coil springs for my 2006 Doublecab TRD 2x4; OEM PN# 48131-AF300/290. I contacted Eibach and they also don't have the direct replacement springs. Anyone know where to purchase from besides going on Offerup or Craigslist?
