2017 Pop & Lock install question
Discussion in '2.5 Gen Tundras (2014-2021)' started by rodl12, Oct 21, 2023.
  1. Oct 21, 2023 at 2:06 PM
    rodl12
    rodl12 [OP] New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
    I have everything installed but the T connectors to the wires for power. The directions do not match my vehicle. The directions call for a connection to a RED wire at pin 18 and a WHITE w/ SILVER DASH wire at pin 9. There isn't any plug that has this combination. I've serched everywhere and I feel like my year Tundra is a unicorn. Can someone give some direction for the connections?
  2. Oct 22, 2023 at 7:58 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    I have a 17 and did mine. Can’t remember where I found the pin out though. I remember it was different than the pin out they gave in the instructions.
  3. Oct 22, 2023 at 10:01 AM
    rodl12
    Rod
    South Jersey
    I guess I'll have to call Pop & Lock tomorrow. Do you remember how you figured it out?
  4. Oct 22, 2023 at 10:09 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    I found a pin out online.
  5. Oct 23, 2023 at 4:06 AM
    rodl12
    Rod
    South Jersey
    Can you explain what that means?
  6. Oct 23, 2023 at 5:05 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    A pin out is a diagram showing what wire goes to what terminal. Someone else before me discovered it and posted online somewhere. It’s been some time and I can’t remember where I saw it. At the time I found it, I was at work and quickly printed it for later. I looked in my Tundra file and it’s not there. I must have tossed it out after I wired it.
  7. Oct 23, 2023 at 8:41 AM
    sonofdad
    sonofdad New Member
    steamboat springs, co
    2017 Tundra SR5
    i installed one of these on my 2017 last spring, don't recall locating the correct wires to be a problem. are you sure you're looking in the right spot?
    here's a 2017 install video i found super-helpful. not sure if you need it, but i have a copy of my pop & lock instructions as a PDF i can share.
  8. Oct 24, 2023 at 3:42 AM
    rodl12
    Rod
    South Jersey
    I saw that video and those are not the same color wires on my 17 Tundra which is why I posted this. I think that is a 2020 Tundra in the video. Here is a picture of my wires that don't have a red wire that the instructions call for. I finnaly got to talk a rep from Pop & Lock last night and he told me it should be the Blue with silver dots on it I need to use. He said he has seen this before on other trucks. IMG_6640.HEIC.jpg
  9. Oct 24, 2023 at 7:26 AM
    sonofdad
    sonofdad New Member
    2017 Tundra SR5
    odd. my wires were as described in the video and the instructions :notsure:
    hope you're able to identify the correct ones and you get this working. good luck with your install and let us know how it goes.
    NewImprovedRon likes this.
  10. Oct 24, 2023 at 3:41 PM
    rodl12
    Rod
    South Jersey
    Just a follow up on my 2017 Tundra SR5 Pop & Lock wire problem. The correct wires for my Tundra are the Blue with the silver dot and the white. The Pop & Lock wires Blue goes to the Blue with silver dot and the Pop & Lock Green goes to the White. Finished it today and it's so nice to have my tailgate lock when I lock the truck! This is definitely a great inexpensive mod for my truck.
  11. Oct 24, 2023 at 4:04 PM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Glad you figured it out.
    rodl12[OP] likes this.
  12. Oct 24, 2023 at 5:52 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Sorry I didn't see your thread previously! I ran into this problem with my 2016 and went by the wire locations instead of colors, and came to the same results you did. Still working great a year later!
    rodl12[QUOTED][OP] likes this.
  13. Oct 25, 2023 at 8:03 AM
    sonofdad
    sonofdad New Member
    2017 Tundra SR5
    glad you got it sorted @rodl12 :thumbsup:
  14. Oct 27, 2023 at 10:27 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes sir, just installed my popandlock today and had the same issue. I back probed the wires to find the correct ones which are the same as yours. 2016 Tundra.
  15. Oct 28, 2023 at 5:23 AM
    MedCityMoto
    We should fill in Pop & Lock to update their instructions!
  16. Oct 29, 2023 at 4:17 AM
    rodl12
    Rod
    South Jersey
    I'm reserving my comment on that. If this has been happening since 2016 from what I know and they haven't revised their instructions which are only online you can fill in the blanks. I offered to send them a photo of mine and they declined. Is what it is.
