GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Oct 23, 2023 at 5:39 AM
    #3871
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Ride is a bit rougher with the 10-ply tire. Very quiet on the highway though. I have no rubbing during during my normal course of travel in forward or reverse. I did have a slight rub in the rear when the suspension was flexed traveling over some unmaintained service roads.
  2. Oct 23, 2023 at 6:56 AM
    #3872
    Upordown
    Upordown New Member
    22 Capstone Supersonic Red
    After a lot of back and forth, finally got new wheels and tires. Went with Alphaequipt Grenade (because of offset being close to what I was looking for) and Toyos (275×70R18).
    1bad2k likes this.
  3. Oct 23, 2023 at 7:55 AM
    #3873
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    Loving the new Falkens. Smooth and quiet and clean out well in the SD (pheasant opener) mud.
  4. Oct 23, 2023 at 4:41 PM
    #3874
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    Heated water through a pressure washer. They will look like new. I've driven work trucks through 100's of miles of mud per day and that has always done the trick.
  5. Oct 23, 2023 at 5:31 PM
    #3875
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    I have some by the chemical guys I believe but I'll verify in a bit when I can get to the bottle. I'm not a professional detailer but have done the research and you want a water based product. . Dries quicker and doesn't sling off. I'll send a pic when I can. It's definitely good stuff.
    Eurodriver[QUOTED] likes this.
  6. Oct 23, 2023 at 6:45 PM
    #3876
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    2024 Tundra Hybrid Platinum
    Thanks! I ordered hub rings but found out that, unfortunately, it was either center cap or hub ring -- because of how the cap connects. If it gives me grief, I'll sacrifice the aesthetic
  7. Oct 23, 2023 at 7:04 PM
    #3877
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    My setup for truck/wheels and tires is the same as you and I just ordered rokblokz. I had them on my 2005 Tacoma and they helped a lot. These stock mud flaps don’t offer much body protection. Also ordered the Romik running boards that are height adjustable, which will allow me to keep them tight to the rockers for added paint protection from mud/rocks. I can see your side steps helped protect the lower portions of your truck as well.
  8. Oct 23, 2023 at 8:46 PM
    #3878
    ColumbiaGorge
    ColumbiaGorge New Member
    Joe
    Columbia Gorge
    24 Limited
    Yes any water based one will do the trick! Oil based makes for messes and ruined wheel rags.
  9. Oct 24, 2023 at 5:31 AM
    #3879
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
  10. Oct 24, 2023 at 10:15 AM
    #3880
    LunaTuna
    LunaTuna New Member
    Tires are FINALLY balanced.... IT TOOK 4 F**** times !
    1) came from custom offsets - vibrations at 60-70 but not crazy
    2)went to local shop with road force balancer - vibrations still there
    3)went to Toyota shop got an alignment and road force balancer - Tires got MUCH more quieter but Vibrations worse than before.
    4)went to local 4*4 shop, they found that toyota was off by 8oz's !! on some wheels...they balanced all tires- Vibrations are pretty down to zero...
    Lesson learned : It's the technician not the equipment. right ladies ;)
    Toyo ATIII 285/70/18
    (had to remove front mud flaps and trim some fabric.. they are around a 34" tire)
  11. Oct 24, 2023 at 3:27 PM
    #3881
    TundraMoe
    I’d love to see those when installed. Please post pics. These mud flaps don’t cut it. I do have the Bora 1.25” spacer so they poke a bit.
  12. Oct 24, 2023 at 4:20 PM
    #3882
    Northern Toyota
    Tires and bilstein
    Subiedepot had them for the cheapest price in Canada with free shipping. Left in my cart for a couple days and received a 5% off code so I pulled the trigger. I just washed my truck and have 2 chips in the bed side above the clear protective tape in front of the rear wheels.
    10-15 business days to get to Ontario then however long to get to me here in NS
  13. Oct 25, 2023 at 8:23 AM
    #3883
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    2023 Tundra 1794 Edition
    For anyone that went from OEM to 275/65R20, did you notice much degradation in ride quality? The 265/60 OEM is a passenger tire, but anything larger takes you to an LT. It is a stiffer sidewall, but curious as to real world observations on the Tundra.
  14. Oct 25, 2023 at 10:03 AM
    #3884
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    There is definitely a difference. Along with the stiffer sidewall, you run LT tires at higher pressure than P rated tires, so it is a compound effect.
    But, even though it is a harsher ride, it is not worse than expected (it would be ignorant to go LT and not expect a difference) and not anything that would be unbearable.
    The looks and the better grip makes up for the harsher ride, for me at least.
    Lebo likes this.
  15. Oct 25, 2023 at 10:42 AM
    #3885
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    Looks good with plus offset
    TundrX[QUOTED] likes this.
  16. Oct 25, 2023 at 10:59 AM
    #3886
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    What size you got on there? Good looking truck. . .
  17. Oct 25, 2023 at 11:05 AM
    #3887
    king.cong.1119
    king.cong.1119 New Member
    Rock warrior wheels with 255/85r17 tires.
  18. Oct 25, 2023 at 12:08 PM
    #3888
    trd1993
    trd1993 New Member
    What a difference 35s make on the truck. Factory wheels looked tiny in the wheel well.
    Falken Wildpeak 35x12.50x18
    Blufin, Morning_Rock, Yaboy and 2 others like this.
  19. Oct 25, 2023 at 12:25 PM
    #3889
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    Thanks! I’ll get some side shots soon. Perfect amount of poke, IMO
  20. Oct 25, 2023 at 5:19 PM
    #3890
    Boerseun
    Ferdie
    Sarasota Florida
    Thanks.
    275/65R20. (34") That's one size up on width and one size up on sidewall from the OEM 265/60R20. I think it makes a huge difference in the looks of the truck.
  21. Oct 27, 2023 at 11:35 AM
    #3891
    Todd34
    Todd34 New Member
    Here's mine with 17" Icon Rebound SLX and Toyo Open Country AT3's in 35 x 11.5.
    HiUp likes this.
  22. Oct 27, 2023 at 12:19 PM
    #3892
    Tundrakup
    Tundrakup New Member
    How'd you swing this? Conversion kit?
    YotaGang0404 likes this.
  23. Oct 29, 2023 at 3:22 PM
    #3893
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Light and narrow if you want MPG, also less aggressive tread designs will help.
    I want the Toyo AT3 to come out in a 35x11x17 (no 11.5 here) in a C sidewall- would be the perfect tire
  24. Oct 30, 2023 at 9:47 AM
    #3894
    BabyMoose
    BabyMoose New Member
    2023 Tundra Limited TRD Off-Road
    CBI bed rack, Decked storage, OVS Nomadic 2 RTT, Ironman DeltaWing 270
    Stock suspension? Also what wheel offset is that? Looks great!
  25. Oct 30, 2023 at 10:55 AM
    #3895
    cvd2312
    cvd2312 New Member
    2023 CrewMax SR5 TRD OR
    Anyone gone from 18’s to 20’s? Looking at some used 20” TRD take-offs. Like the look of them but wondering if I’d regret 20’s.
    I don’t off-road, just normal driving and towing a 28’ travel trailer.
  26. Oct 30, 2023 at 7:56 PM
    #3896
    Todd34
    Todd34 New Member
    Thanks! No, it’s not stock. Dobinson’s IMS 3/2 suspension. The wheels have +25 offset.
    BabyMoose[QUOTED] likes this.
  27. Oct 31, 2023 at 3:39 AM
    #3897
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    You will notice a slightly firmer ride, but nothing crazy. I swapped an old f150 from OEM 18s to OEM 20s and had no regrets. I was only highway driving and towing my boat at the time.
    The change in ride quality is MUCH less than the change from a SL tire to an E range.
    Boerseun and cvd2312[QUOTED] like this.
  28. Oct 31, 2023 at 11:20 AM
    #3898
    rajlovermaster
    rajlovermaster New Member
    Jay
    HI..I have 2022 Tundra and thought to change the tire. I don't have any knowledge about them so i contacted one of the Tire guy on FB and he said go with 20x9 with 265/50r20...and the tire is Americus 265/50r20 XL rugged...
    how is this combination? i dont want to do any lift.
  29. Oct 31, 2023 at 11:33 AM
    #3899
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Those will be smaller than the OE size of 265/60/R20. The XL tire will be heavier than the OE tires so you might see your mpg's go down.
  30. Oct 31, 2023 at 11:44 AM
    #3900
    Boerseun
    Ferdie
    Sarasota Florida
    Not sure what your style is and what look you are going for, but 265/50R20 is smaller than OEM; it will be a big wheel(rim) with low profile sidewall.
    Most people on here go for more sidewall than OEM.
    I have 20" wheels and installed 275/65R20 tires (up from 265/60R20 OEM) and I think it looks good. It fills the wheel wells a bit better than OEM.
    Current 275/65R20
    These are OEM 265/60R20. You can see the sidewall difference compared to the above. If you go with the 50 sidewalls it will be less than these, and overall smaller wheel. Just my opinion, but I don't think it will look good if the wheels are even smaller than OEM.
