Does anyone have experience with the ReadyLift 3 inch for AVS equipped trucks?
Discussion in '3rd Gen Tundras (2022+)' started by planehappy, Oct 22, 2023.
  1. Oct 22, 2023 at 10:24 AM
    planehappy
    planehappy [OP] New Member
    As title says. I have a 2022 with the full AVS package, and now ReadyLift has an option for this in a 3 inch lift. Wondering anyones experience with this and if it kept their stock ride quality?
    Gunman45 likes this.
  2. Oct 22, 2023 at 10:57 AM
    Gunman45
    Gunman45 New Member
    Raymond
    2024 Wind Chill Pearl Platinum
    Just curious as to where it showing it’s compatible with the AVS? I’m on the fence with the westcott preload as I’ve heard it makes the ride stiffer.
  3. Oct 22, 2023 at 12:46 PM
    planehappy
    I had called ReadyLift yesterday and was told 69-52220 is their 2 inch for the AVS and
    69-2330 is the 3 inch for the AVS
  4. Oct 22, 2023 at 1:20 PM
    Gunman45
    Gunman45 New Member
    Raymond
    Interesting… looks like I’m gonna go with ready lift!
  5. Oct 22, 2023 at 2:23 PM
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    I don't have AVS but I have the rear airbags and plan to use the ReadyLift 3" kit and go on 35"s. Would love to get some feedback too before buying.
  6. Oct 23, 2023 at 11:20 AM
    planehappy
    I didn’t know you could get rear bags without the full avs.
    it sounds like we are all just waiting for someone else to try the readylift lift kit first, lol!
  7. Oct 23, 2023 at 12:45 PM
    az 3rdGen
    Arizona
    Yeah, what my truck has is the base suspension with rear air bags instead of a coil spring. I think the ReadyLift is the kit for both types of trucks. I plan to buy the ReadyLift kit in February and then about 6 months later I want to get Fox coil overs in the front and struts in the rear. I just need the ReadyLift for the Airbag spacer and brake line brackets really.
  8. Oct 23, 2023 at 1:58 PM
    Limited 23SC
    Limited 23SC New Member
    2023 Limited
    I have the rear bags on my 23, went with the 2" ready lift. It just a spacer for up front which ill change out after i get my bumper and winch put on. The back has everthing for the airbags , breaklines, shock extenders,and other brackets
  9. Oct 23, 2023 at 3:13 PM
    planehappy
    Thanks for the information on what it comes with. I get it’s a spacer kit. That’s all we can do with the AVS system if I understand correctly. I am just hoping to be able to do something that doesn’t mess up the comfortable ride.
