Show us your EV charging setup
Discussion in 'Electric Vehicles (EVs)' started by Bob, Oct 22, 2023.
  1. Oct 22, 2023 at 12:17 PM
    Bob
    Bob [OP] Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    How does your house/condo/apartment/rental property EV charging setup look like?
    ToyoMafia, NWPirate and T-Rex266 like this.
  2. Oct 22, 2023 at 12:33 PM
    Runs up and under to the basement and out to the breaker panel (NEMA 14-50)
    ToyoMafia, NWPirate and Bob[OP] like this.
  3. Oct 23, 2023 at 3:13 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I'm gonna jump in here when I get pictures.
    T-Rex266 likes this.
  4. Oct 23, 2023 at 1:05 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    don't laugh.
    had to use an old 110v - converted it to 220...so only 12amps.
    the red crate is the Harrop box...next to it is the spare rear tire - everyone has a spare rear tire, right?
    and yes, the charging cable is hanging on the joist...so that "someone" does not run over the cord.
    Bob[OP], NWPirate and T-Rex266 like this.
  5. Oct 23, 2023 at 1:12 PM
  6. Oct 23, 2023 at 1:17 PM
    NWPirate
    Zach
    WA
    :laugh:
    Sorry. Any plans to upgrade the circuit?
    Bob[OP] likes this.
  7. Oct 23, 2023 at 1:26 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    No. The main panel is on the other side of the house. $3800 for the run
  8. Oct 23, 2023 at 1:31 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I’ll post our other charger as soon as we get back up there
    it’s a bit cleaner install. Full 48amp
    NWPirate likes this.
  9. Oct 23, 2023 at 1:32 PM
    NWPirate
    Zach
    WA
    GTFO :eek2:
    In conduit or just romex in the attic? How many feet do you think the run is?
  10. Oct 23, 2023 at 1:33 PM
    NWPirate
    Zach
    WA
    Different house?
  11. Oct 23, 2023 at 1:35 PM
    I think the lake house
  12. Oct 23, 2023 at 1:36 PM
    I think mine was close to 2k. Mainly material for the run.
  13. Oct 23, 2023 at 1:41 PM
    NWPirate
    Zach
    WA
    If a contractor bid it, they're at least getting $100/hr for labor.
    Either way, it's clean and done right
  14. Oct 23, 2023 at 1:49 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    lake house
    NWPirate[QUOTED] and T-Rex266 like this.
  15. Oct 23, 2023 at 1:51 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Conduit. Garage is detach. So allllll the way around house
    NWPirate[QUOTED] likes this.
  16. Oct 23, 2023 at 1:57 PM
    You dont have to have a sub from Tesla's site install. I used one I knew of that has installed plenty of them and is a certified master electrician.
    nobodyintexas and NWPirate like this.
  17. Oct 23, 2023 at 2:04 PM
    NWPirate
    Zach
    WA
    Or, you can do it yourself for peanuts. :cool:
  18. Oct 23, 2023 at 2:28 PM
    RIP @T-Rex266
  19. Oct 23, 2023 at 2:36 PM
    NWPirate
    Zach
    WA
    :D
    It's ok, $2k is nothing when you got T-Rex money!
  20. Oct 23, 2023 at 3:06 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Using the Tesla charger at 120v it almost burned my house down. Fried every neutral in the panel so I installed the NEMA at 48amps and it works great. Cost me under $50. Also helped that my panel is in the garage. image.jpg
    T-Rex266 and NWPirate like this.
  21. Oct 23, 2023 at 3:42 PM
    NWPirate
    Zach
    WA
    Flip that outlet bro
  22. Oct 23, 2023 at 3:45 PM
    ToyoMafia
    Magic carpet.
    The outlet is ont the other side of garage. I still need to strain relief it so it goes upwards and over all the BS in the garage.
  23. Oct 23, 2023 at 3:46 PM
    ToyoMafia
    Magic carpet.
    It was actually intentional
  24. Oct 23, 2023 at 3:50 PM
    NWPirate
    Zach
    WA
    And yeah, PSA for anyone else that's curious.
    *When charging on a 120v 20A circuit, make sure it's dedicated and you only pull 16 amps max on that circuit. Breakers are not designed for continuous max current (20A draw on a 20A breaker).
    Confirm all connections are tight and you'll be just fine.
  25. Oct 23, 2023 at 3:51 PM
    NWPirate
    Zach
    WA
    Copy that. :thumbsup:
    T-Rex266 and ToyoMafia[QUOTED] like this.
  26. Oct 23, 2023 at 3:51 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I had our o&g electrician do ours. Hence the hoopty
  27. Oct 23, 2023 at 4:31 PM
    That wire is gonna fray out with it flipped like that sooner than later
  28. Oct 23, 2023 at 4:36 PM
    ToyoMafia
    Magic carpet.
    Fine Sean I’ll push it to the top of my honey do list.
  29. Oct 23, 2023 at 4:36 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    agreed
    example, on 48amps. The charging cord gets damn near hot
    Tesla don’t play
  30. Oct 23, 2023 at 4:40 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Could not resist.:)IMG_5273.jpg
