23 tundra alignment question
Discussion in 'Suspension' started by 23tundra75002, Aug 8, 2023.
  1. Aug 8, 2023 at 10:42 AM
    23tundra75002
    23tundra75002 [OP] New Member
    Dallas
    2023 Tundra Platinum in celestial silver
    Have a question about alignment. The trucks pulls to the right and this is the second alignment done at the dealership.
    23 tundra platinum, stock suspension but with 275 65 20 tires.
    I think I need them to adjust caster to closer to 4 to eliminate the right pull.
    But my question is why I have a range of negative numbers for toe? All the other alignment paperwork I have seen for the 3rd Gen is a range of positive or toe in number.
  2. Aug 8, 2023 at 10:48 AM
    23tundra75002
    Dallas
  3. Aug 8, 2023 at 1:08 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Your taller tires have changed the vehicle height. So, it's likely one of the taller specs applies to your truck. If you look at the chart Ryan provided, the taller height specs do in fact have a negative toe-in.
    Assuming that's correct, your caster should be closer to 5.7 degrees according to the chart. Also, the chart clearly says the left to right difference in caster should be +/- 0.75 degrees maximum. Yours is 1.3 degrees, which is clearly out of spec. I think you have a bone to pick with the service manager at your dealership.
    23 Platinum and (deleted member) like this.
  4. Aug 8, 2023 at 1:27 PM
    23tundra75002
    Dallas
    Thanks for the info. Yea I’m definitely going to let them know. Brought the truck in the 2nd time because it was pulling right after the initial alignment and all they did was a toe alignment (which doesn’t really affect the “pull”). Just ran out of time yesterday.
    I do wonder if I still should have them adjust the toe to something like .10 as the Westcott video had a toe in and that truck I believe was lifted or modified.
  5. Aug 8, 2023 at 1:48 PM
    Matt2015Tundra
    2023 1794 CrewMax
    Alignment specs, including toe-in, all depends on vehicle height, as clearly shown in the chart. I would not vary from the specs in that chart.
    I suspect your dealership is neglecting to measure the vehicle height, then plug in the correct specs to their alignment computer.
    I would visit the dealership with that chart in hand. Then I'd ask the tech what the vehicle height measurement is. Then use the spec that correspond to that measurement. Your right pulling problem is undoubtedly due to the right caster angle being 1.3 degrees less than the left. It's compounded by the fact that you don't have enough caster on either side based on the vehicle height.
  6. Aug 8, 2023 at 6:10 PM
    dogsleds_t100_tundra
    dogsleds_t100_tundra New Member
    '23 Tundra SR5 TRD OffRoad AG and '97 T100 4x4
    275/70/18 AT3, Elka IFP 2.0, Aftermarket Speakers, Sub, Amp. Ceramic Window Tint, Color matched grill surround and rear bumper panels, Orvis Backseat Protector for K9s, OEM Black Exhaust Tip, OEM Black Tailgate badge insert.
    Excellent chart. How is height measured i wonder? I recently installed slightly larger tires and planning to do an alignment just in case slight adjustment is needed.
  7. Sep 20, 2023 at 10:13 PM
    Wallatundra
    Wallatundra New Member
    Brandon
    21 tundra
    Kings. Magnusson. Jba arms. Bed exit exhaust..electric cutouts ..35s
    Alignment is off center of wheel at ride height and center of lower cam adjuster nut. Ive put on a few Wescott with 35 on 22 and 23 tundra and being 35 is out of chart spec. I set them at 4 ° and 0 camber with -.05 total front tow and tires are good after 20k. On pros....
  8. Oct 23, 2023 at 11:09 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Being a DIYer, how would one go about getting this measurement?
